Controlling a motor (stepper?) with the Propeller
I have started a new job where I am building test fixtures for new products. I have the fixture built that uses a compact screw jack rated for 500 lb lifting. Originally I used a custom handle on the side shaft of the jack but I had to turn in 20 turns to lift the jack 1 inch so I decided to go with an electric drill. I found an 8 Amp one online and it works well. On the side shaft of the jack, I have attached a corded 3/8" Dewalt DWD112 VSR drill (8A, 120vac, 650W, 0-2500RPM). It has more than enough torque and drive to lift up a few hundred pounds on my fixture. However, after going through a review, the other Engineers thought I should use a stepper motor more permanently mounted to the 80/20 aluminum framed fixture. I guess they were afraid of someone just taking the drill off of the jack side shaft and it never being seen again. I'm not a mechanical engineer but electrical engineering trained so working with this is new to me.
What I wanted to find out is how to "size" a stepper motor or some other kind of controllable motor (with control buttons for lifting the jack "Up" and "Down"). I did see that the screw jack has an input torque of 17 in.-lbs @ 500 max rpm. How do I convert the information I have on the screw jack and drill(?) to what will be sized right for a Propeller to control? Where do I begin? I would think that someone has done this before or something like it. I would like to use a Propeller as I have one already and a little familiar with how it works but never worked with stepper motors (only those Parallax smaller Servo motors with a Basic Stamp and SX28).
Can anyone help me here? Let me know any other information you need to help me with this.
Thank you
Thank you
With all respect, if you were doing it on my time, I'd have you go out and purchase an off-the-shelf solution.
Mickster.
Please note I said GUESStimate. Knowing the desired speed, applied force, and torque required to apply that force would allow you to calculate the minimum torque required from the stepper.
It sounds like you don't need super precision, so yeah..I'm with the DC motor thought.
Strong DC motor + H-Bridge w/ support circuit + Then add safety switches to the top and bottom of the rig so that a user can't shove it all the way up or all the way down. Or of course you could just monitor the current and assume that if the motor is maxing out the current drive, they probably jammed it up against the top or bottom.
Either way, seems like a pretty straight forward setup.
What I found from McMaster-Carr was the following:
I knew that the compact screw jack had an input torque of 17 in-lb @ 500 rpm max. They had a right angle DC Gearmotor that was 1/4 HP with a listing of 30 in-lb and 500 rpm for $469. I beleive this will cover it (Does this sound right?). However, it works on 90 vdc and they said I need an AC to DC Motor Speed Controller (reversible) so this is another $355. Then I need a 2 button handheld Pendant switch ($88) for up/down movements with 2 limit switches ($43 X 2 = $86) to stop the motor if it goes too high or low on the screw jack thread. Total cost here = $998. Plus wire, cable snaps, plug, etc. = $1064 spent.
What's ironic is that I did all this with a $70 drill on the shaft of the screw jack - but for a more permanent solution so that the drill doesn't get legs and get taken is to spend almost $1100. Hmm
Anyway...Is there anyway with these items, I can still control the DC gearmotor with a Propeller (or is that only possible on Stepper motors, servos, etc.)?
Tim
Perhaps some creative modification of the drill assembly like removal of the battery compartment and the chuck would discourage the drill from growing unwanted legs. Even with the drill modified I would put some limit switches on the system. Micro switches are cheap at Radio Shack.
Jim
Guarding, limit switches, and insulated/isolated controls are all things brought to us by dumbasses. Sure, I have no problem with an unguarded table saw or cutoff saw, but if some idiot horses around or is high, tired, or just stupid, then it spoils it for the rest of us.
