Recycling Video Generators
A computing project uses LED outputs and no Video Generators are needed. However, the Propeller chip has two independent unused generators in each Cog. Instead of 16 generators going to waste, how can Video Generators be recycled into other purposes? Thank you.
One video generator per cog.
Well I've used one to pump bytes down a parallel interface to a LCD (to its framebuffer RAM, not VGA), but any output-only bytewide channel is suitable - fast R-2R DAC, sending addresses to ROM/FLASH/RAM (and data unless ROM). Feeding a fast parallel-in serial-out shift-register? Fast transfer between Props?
And once you bring in the TV modes there are probably some clever RF signal generation possibilities.
Does each generator occupy the Cog with its function or is it independent like a counter?
The shift register could have some very interesting applications. What source is available, in addition to the Propeller Manual, to learn about a Generator's shift register functions? I'm currently looking at the HYDRA book.
I'd recommend reviewing the datasheet adn http://propeller.wikispaces.com/Video+Generator. But the basic overview is the video generator is controlled by the VCFG and VSCL registers and clocked by CTRA. Data is fed into the shift register & MUX using the WAITVID instruction which blocks until the shift register is reloaded. (If no WAITVID is active when the VSCL counter expires then it uses whatever is on the bus.)
I've also used it to do high speed SPI. For each data bit, you create two 2-bit pixels. The first pixel is your data bit + a high clock bit. The second pixel is the same data bit value, but this time with a low clock bit. Each nybble (4 bits) is a single data bit, so you can send 8 bits per 32 bit waitvid instruction. It takes some effort to format the data to output it this way, but once it's done, it can be sent very quickly.
