HELP with BOE BOT (IR's and QTI's)
Hello, in my project I want the BOE BOT make two processes. The first one is with two IR pairs avoid objects and the other is with QTI's sensors follow a black line. I'm stuck in making the robot come back to the black line after it avoids an object. In my programm the robot perfoms the second process successfully and I am trying to resolve my problem with different routines for avoiding objects.
00000_sto_L-R.bs2 Can anyone help me?? (Comments at the side are in Greek).
Thanks a lot.
Thanks a lot.
[video=youtube_share;xkYpWYhpIis]
Like most of my good ideas it came from Robot Builders Bonanza Here's the code:
' ================================================== ============================ ' ' File...... SimpleWallFollowing.BSE ' Purpose... The robot follows a wall using a single ultrasonic sensor ' Author.... Martin Heermance ' E-mail.... mheermance@gmail.com ' Started... 2012 March 31st ' Updated... 2012 April st ' ' {$STAMP BS2e} ' {$PBASIC 2.5} ' ================================================== ============================ ' ------------------------------------------------------------------------------ ' Program Description ' ------------------------------------------------------------------------------ ' This program can be used with a CBA or Boe-bot to follow a wall using only a ' single ultrasonic sensor. The basic concept used is from page 609 of "Robot ' Builder's Bonanza" by Gordon McComb ' ------------------------------------------------------------------------------ ' Revision History ' ------------------------------------------------------------------------------ ' Pin allocations. You might need to tweak the Ping))) pin. Ping PIN 10 ' Pin for PING))) Sensor RMotor PIN 12 ' Pin for right servo LMotor PIN 13 ' Pin for left servo ' These values need tweaking for each robot's servos. Speed075L CON 831 ' Fast left Speed075R CON 658 ' Fast right Speed050R CON 685 ' Slow right (to arc) ' These values control distance from the wall and sharpness of left turn WallDistance CON 5 TurnCount CON 40 ' Standard values from Ping))) example Trigger CON 5 ' trigger pulse = 10 uS Scale CON $200 ' raw x 2.00 = uS RawToIn CON 889 ' 1 / 73.746 (with **) RawToCm CON 2257 ' 1 / 29.034 (with **) ' Trigger Ping))) IsHigh CON 1 IsLow CON 0 ' This program is so simple it only needs a single variable to ' compute and test the distance to the wall. X VAR Word ' Execution starts here Main: ' Pause at start of program to let user set down robot. PAUSE 1000 DO GOSUB PingDistance ' If we're far enough from the wall the continue the arc. IF (X > WallDistance) THEN ' Pulse once PULSOUT RMotor, Speed050R PULSOUT LMotor, Speed075L PAUSE 15 ELSE ' Pulse turn count times to strongly turn away from the wall. FOR X = 1 TO TurnCount PULSOUT RMotor, Speed050R PULSOUT LMotor, Speed050R PAUSE 15 NEXT ENDIF LOOP ' We'll never get here, but it's nice coding style. END ' PingDistance - reads the distance at the current head angle. ' Inputs: ' Outputs: ' X - distance in inches. PingDistance: Ping = IsLow ' make trigger 0-1-0 PULSOUT Ping, Trigger ' activate sensor PULSIN Ping, IsHigh, X ' measure echo pulse X = X */ Scale ' convert to uS X = X / 2 ' remove return trip X = X ** RawToIn ' convert to inches RETURNAttached for easy downloading:
Attachment not found.
