Out of variable space (programming servos)
I am currently trying to program 12 servos using a BS2, a Board of Education, and a Propeller Servo Controller Unit. The way I currently have my program setup I can only assign 10 servos without getting the program error "out of variable space". I am a serious novice when it comes to programing in general, so I do not know if there a way to program up to12 servos with my current setup. Or perhaps i will have to upgrade my hardware?
Here is the program I am trying to use to control the servos.
5testForum.bs2
5testForum.bs2
'{$STAMP BS2} '{$PBASIC 2.5} ' Set baud for all STAMP versions #SELECT $STAMP #CASE BS2SX, BS2P N2400 CON 1021 + $8000 N38K4 CON 45 + $8000 #CASE BS2PX N2400 CON 1646 + $8000 N38K4 CON 84 + $8000 #CASE #ELSE N2400 CON 396 + $8000 N38K4 CON 6 + $8000 #ENDSELECT Sdat CON 15 baud CON 396 FOOT1 CON 8 FOOT2 CON 15 FOOT3 CON 11 FOOT4 CON 12 LEG1 CON 6 LEG2 CON 5 LEG3 CON 9 LEG4 CON 10 ARM1 CON 4 ARM2 CON 2 ARM3 CON 9 ARM4 CON 1 DEFAULT_RAMP CON 10 FOOT_UP CON 850 FOOT_DOWN CON 650 LEG_UP CON 1000 LEG_DOWN CON 500 ARM_UP CON 900 ARM_DOWN CON 700 'Vars id VAR Word ramp VAR Byte position VAR Word delay VAR Byte Init: ramp = DEFAULT_RAMP 'speed adjust delay = 100 Main: id = FOOT1 position = FOOT_UP GOSUb Write_PSC id = FOOT2 GOSUb Write_PSC id = FOOT3 GOSUb Write_PSC id = FOOT4 GOSUb Write_PSC GOTO Main Write_PSC: SEROUT Sdat,Baud,["!SC", id, ramp, position.LOWBYTE, position.HIGHBYTE, CR] PAUSE delay RETURNThanks for the help Mike G.
