Proto Board input voltage
I'm hoping to put the Propeller ProtoBoard into my car as an accessory. In my application, the prop needs little current (only two cogs running, 80MHz, probably significantly downclockable), and the only other power is for a 10K pullup and 10K load on an I/O pin.
So, I figure ~45 mA. The LM1086-5 should handle at least 25 volts input. At 25v in, power dissipation in my application would be 900milliWatts, which I think would be just on the edge of what the protoboard can dissipate. 15v (very high for running car, more like 14.2) would have 450mW dissipation in the regulator.
What I'm more concerned about is C3, which the schematic only lists as 10uF, and has no voltage rating I can find. Can I provide 15v in to the protoboard without popping a cap?
Is there some reason not to put a simple 3 terminal regulator in series
and drop town to 6 to 9cDC?
Car electical systems are noisy so you should add some filtering to the circuit. An inductor and capacitor are a good idea.
