Guidance on setting up Eclipse to build. — Parallax Forums
photomankcphotomankc Posts: 943
edited 2012-08-09 01:34 in Propeller 1
Ok on my bigger workstations I have to admit I got real cozy with Eclipse doing the dot completion, header/source switching, auto function skeleton, stuff. Is there any guidance on how I can get Eclipse to just be able to build the project? I don't care if I still use SimpleIDE to load the program but getting as far as building with Eclipse would be kind of cool. Right now I do it a bit like Aurduino and edit in Eclipse and build/load with SimpleIDE. Don't really know where to start to get Eclipse configured to use PropGCC to compile and link.
  • jazzedjazzed Posts: 11,803
    edited 2012-08-08 22:47
    Here's a simple example I put together last year on Eclipse Indigo.
    You can even run it with the loader if the configuration is right.
    There are challenges though.
    * I have no idea if just copying the .zip folder will work.
    * The project must be selected at all times (why does it ever get deselected?).
    * Can't pass input on the output window to a program.
    * User must manually terminate the program if the terminal is used.
    * Ctrl+C in the output window doesn't work.
    Netbeans can also be used. Both are equally hard to configure.
  • amossamamossam Posts: 35
    photomankc wrote: »
    Hey!
    I'm using Eclipse Juno on OSX, but this should work, you only need to adjust paths...
    So, I'm using C/C++ project with MakeFile Project / Empty Project -> "Other Toolchain"
    Then, i create Makefile with folowing content (you should adjuct paths...):
    (in SRC line you just write filenames in your project...)
    CC            = /opt/Development/parallax/parallax/bin/propeller-elf-gcc
    CFLAGS         = -Os -mlmm -I . -I /opt/Development/parallax/parallax/propeller-elf/include -L. -ltiny -Wall -fno-exceptions
    NM             = propeller-elf-nm
    SRC            =    main.cpp
    OBJ            =    $(SRC:.cpp=.o)
    EXE            =    main
    all: $(SRC) $(EXE)
    $(EXE):    $(OBJ)
        @(cd build; $(CC) $(LDFLAGS) $(OBJ) -o $@)
    %.o:    %.cpp
        @(mkdir -p build)
        @(cd build; $(CC) $(CFLAGS) -c ../$< -o $@)
    clean:
        @(rm -rf build)
    And then in Project settings, C/C++ Build -> Enviroment I just insert INCLUDE variable with path to propeller include headers.
    Also in Project settings, Run/Debug settings, I add new launch settings with following:
    C/C++ Application:
    "/opt/Development/parallax/parallax/bin/propeller-load"
    and in Arguments:
    -I /opt/Development/parallax/parallax/propeller-load
    -b QUICKSTART
    -p /dev/tty.usbserial-A100S8K4
    ${workspace_loc}/${project_path}/build/main
    -e
    -r
    -S
    Code completiton, warnings works, everything. when i build project it builds it, and when i run project it uploads it to propeller...
    my 1 cent...
