Raspberry Pi teases finished Gertboard I/O extender, revs creative engines — Parallax Forums
    edited 2012-08-08 18:39
    Bah! Another Arduino board. Should we really be advertising that here?
    Now that we have Propeller dev tools running on the Pi I want to those kind of boards using Propellers.
  • rod1963rod1963 Posts: 752
    edited 2012-08-08 19:34
    Give the man a cigar.
    Nice board, Gert was really smart going with the Arduino. It automatically gave the Raspberry automatic access to the Arduino user community which previously felt threatened by the Raspy. Now they get exposure to Linux, ARM and the rest of the goodies.
    Win, win. That's how the game is played.
    edited 2012-08-08 23:06
    Rod1063,
    that is how the game is played
    Yes. And that is why I want to see a Propeller board for the Pi.
    All those hundreds of thousands of Pi users can get introduced to the wonders of the Propeller and Parallax.
    Having the Arduino guys attracted to the Pi via a Gert board may be good. They are just the kind of people that might appriciate a Propeller having seen the limits of the AVR.
    To that end I have been spending more time than I should packageing propgcc and simpleide for the Raspi. It is working very well so far.
  • jmgjmg Posts: 15,193
    edited 2012-08-09 02:36
    jdolecki wrote: »
    i/o board for the Rasberry Pi
    They swapped PIC for AVR, but same package, so that is not much effort. No Debug on-board ?
    What is stranger, is the shift from SMD LED resistors, to SIP networks.
    They seem to be pushing this as an expensive 'kit' @ £30 (!), but there are still many SMD parts present ?
    The problem with a SIP, is if you want to make one pin high impedance, you simply lift the SMD part, when it is element #3 in a network, that is much harder....
    It does not look like this stacks on the RaspPi ?
    So, better value is surely something like a Prop QuickStart, or this new offering for $17, from TI,
    http://www.ti.com/tool/launchxl-f28027
    which does include Debug, even Opto-Isolated Debug.
    edited 2012-08-09 02:54
    No the Gert does not stack on the Raspi. It is a much bigger board than the Raspi.
    I want to see a "Propeller Pi" board that sits on top and carries a Prop.
  • jazzedjazzed Posts: 11,803
    edited 2012-08-09 10:38
    Heater. wrote: »
    A Propeller Pi I/O board would be fairly simple to make, but what features would you like? Another thread?
    I'll make it if no one else does although I doubt finding an eager/competitive volunteer would be a problem considering the number of RPi units sold.
    Is there a published dimensions spec? I haven't found it. Not having one is a little scary.
    edited 2012-08-09 10:42
    The thing that makes the Gertboard attractive is that it's friendly to non-geek users. Gert took into account the target audience: namely newbies and HS kids. Sure he could have picked anyone of a half-a-dozen processors but he picked the the one that had a important element - a easy to use development environment and a significant user base.
    If a enterprising Prop user wants a piece of that action, they'll have to do more than roll out a just a board or using a existing one and a bare bones GCC. That means a development environment that mirrors the Arduino to a degree, good manual aimed at newbies and teenagers with a truck load of worked out examples. It wouldn't be hard to adapt current Parallax literature for this part. A site dedicated to helping said users as well. Can be a blog.
    edited 2012-08-09 11:06
    @Jazzed
    If you are into designing a "Propeller Pi" board that is fantastic.
    Two things it needs: An RTC because the Pi does not have one, a Propeller of course.
    There is already a thread bouncing these ideas around.
    @rod1963
    Pay attention, we already have a Prop IDE as simple as the Arduido's. SimpleIDE by Jazzed. Works fine on the Pi and allows development in GCC or Spin.
    The docs and other support is a big other problem but we are already far along the road.
    edited 2012-08-09 11:16
    Heater. wrote: »
    @Jazzed
    To reiterate: "I'll make it if no one else does ...."
    edited 2012-08-09 11:24
    Yep, it's one of those things that just has to be done. For sure I know of half a dozen people who want it already.
    edited 2012-08-09 11:30
    This thread has kind of died but TonyD has built a couple board for the Raspberry Pi, so he found some dimensions some place.
    Other than the fact that neither of my wireless USB keyboard/mouse combos are working well with my RPi :frown:
    edited 2012-08-09 12:21
    Heater
    Just having a C compiler with a IDE isn't enough. You're gonna need a library of easy to use set of virtual peripherals as well. Along with a user manual that targets newbies and Arduino users with plenty of worked out examples that are specific to the Prop board. The same way mbed got people interested in ARM micro-controllers. They put out a superior software system that targeted novices and did a good job.
    In short, respect the Raspberry community, don't roll a out uber geek board that appeals to handful of Prop heads and can only be found by contacting a certain guru poster on a full moon. Put out a polished product with real documentation that newbies can learn from and gets a good review from the Raspberry community. Remember that's your customer base, not a dozen or so Prop heads who need something else.
    edited 2012-08-09 12:30
    rod1963 wrote: »
    Some of our friends inside of Parallax are working on the Propeller solution now.
    It will be revealed in time with that Parallax special sauce.
    SimpleIDE with SPIN and PropellerGCC figure prominently.
    edited 2012-08-09 12:41
    rod1963,
    I totally agree. A board on its own is not enough.
    But the SimpleIde works for Spin so I hope all the existing support for Spin on the Propeller can be used. That is to say all the educational materials Parallax has, all the objects in OBEX etc etc.
    If that is not enough existing material I don't know what can help.
    C on the Propeller is a whole new ball game so I don't know where that goes in this picture.
    I don't care actually. I want an ARM + Prop. It's been a dream for years and now it is very possible with little effort and low cost. If anyone else likes it all the better:)
  • TonyDTonyD Posts: 210
    edited 2012-08-10 06:06
    jazzed wrote: »
    I think there's a number of us wanting to same thing, so is it time for a group project to get the Propeller and Raspberry Pi combo going?
  • ColeyColey Posts: 1,129
    edited 2012-08-10 06:28
    TonyD wrote: »
    Yes! Count me in....
    edited 2012-08-10 07:22
    Hmm name for a Pi prop ..... blended Pie . ( sounds like a smoothe ) baked prop .
    Prop al la mode . Pi Al la mode ..:innocent:
    edited 2012-08-10 08:41
    Mine will be called "Propeller Pi" putting the emphasis in the right place.
  • RsadeikaRsadeika Posts: 3,861
    edited 2012-08-10 09:27
    Which one will be in control? RaspProp or maybe a PropRasp. I am starting to like the sound of PropRasp.
    edited 2012-08-11 04:35
    Heater has modified Propeller loader now so that you can program the Prop directly from the Pi's UART.
    http://forums.parallax.com/showthread.php?141469-SimpleIDE-for-Raspberry-Pi-Raspian-update-v0.8.4&p=1117008&viewfull=1#post1117008
    edited 2012-08-11 07:06
    I am up for designing hardware but I have not ordered aPi and know nothing about *nix.
    So, in addition to RTC, what is required?
    SMT or t/hole?
    edited 2012-08-11 08:38
    TonyD wrote: »
    Indeed.
    Is there a single thread where the features can be sorted? If not can you start one?
    Maybe there is more than one board. What about ADC's, etc.... ?
    Heater mentions RTC ... even that will require some kind of software/interface.
    Having a reference point for software would be just as important as the board.
    And what about RPi linux libraries?
    Maybe a Propeller PI "social group" would be useful?
    I'm often frustrated trying to find things in the forum - would a social group help?
    --Steve
    edited 2012-08-11 10:50
    How about calling it the "PropPi' board ? Already has a well known logo if we could get permission to use it.
    edited 2012-08-11 16:13
    Jazzed,
    The RTC is kind of on its own. I believe there are drivers for some RTC chips over i2c for the Pi so it is connected to the Pi not the Prop.
    I'm all for simple here. Break out the I/O and thats it.
    edited 2012-08-13 01:06
    Heater, if that's all you need then I suggest TonyD's protoboard as a starting point, the footprint for that would be perfect for what you need.
    Have you got any info relating to the type of RTC required?
