4D uLCD connectivity issue — Parallax Forums
Phillysteak527Phillysteak527 Posts: 5
edited 2012-08-08 14:34 in Propeller 1
Hello everyone. I'm extremely new to Spin programming and i've run into a roadblock. I'm having difficulty in sending commands to a 4D LCD using the "Full Duplex Serial" object. I've tried to use the uOLED object from OBEX, but I believe it isn't the object that is causing the issues it's the way i'm trying to send commands. For instance if I am attempting to send the command "Print" via a serial link how would the syntax look? I noticed that in the 4D uOLED object it sends commands as such:
SERIAL.tx ("C")
SERIAL.tx (X)
SERIAL.tx (Y)
SERIAL.tx (RADIUS)
SERIAL.tx (R.byte[1])
SERIAL.tx (R.byte[0])
WAITACK
The above code should generate a circle, i've tried this syntax but still can't communicate with the LCD. Can anyone direct me to a tutorial or manual on how to properly communicate with peripherals using a serial link? Thank you in advance.
  • TubularTubular Posts: 4,768
    edited 2012-08-08 05:33
    Hi and welcome to the Propeller forums.
    With the serial variants of the display it's normal to send a 'U' character first so the display knows what baud rate to receive at. I think you also need a CR afterwards, but I'll double check that.
    I have some example code while I'll find and post shortly.
    regards
    tubular
    edited 2012-08-08 05:40
    oops the code I was thinking is actually VB code not propeller, but here's the startup sequence. The tdelay are delays in seconds. The CR's don't appear to be required. I remember some strange situation where the screen wouldn't erase 100% of the time, hence the two 'E' commands to erase the screen at the start.
    'Initialise OLED
    OPEN "COM2:19200,n,8,1,cs0,cd0,ds0,rb2999" FOR RANDOM AS #45
    tdelay 2
    OLEDTransmit "U"
    tdelay .1
    OLEDTransmit "E"
    tdelay .1
    OLEDTransmit "E"
    tdelay .1
    S$ = "p" + CHR$(0)
    OLEDTransmit S$
    S$ = "G" + CHR$(0) + OledY$(0) + CHR$(0) + OledY$(16) + CHR$(109) + OledY$(16) + CHR$(0) + CHR$(31)
    OLEDTransmit S$
  • Phillysteak527Phillysteak527 Posts: 5
    edited 2012-08-08 06:58
    After instituting your suggestions and still not making progress I checked the RX/TX lines with my scope and I am not getting any transmission to the uLCD. The program hands as it waits for the ACK signal. Any suggestions?
    That's no good. Can you pls show me the lines of your program where you initialise the SERIAL object? As in setting pin numbers etc.
