Switch to Propeller
NWCCTV
So, I am considering making the switch from BS2 chips to the propeller. What should I start with that would actually be usable in my larger robot project that I am working on? Also, Has anyone done work with the Prop and MS Robotics Studio 4.0 or even in C# 2010? This is pretty much a must for my project and I have a portion of the concept down in PBasic. If I decide to make the transition I need it to be fairly smooth. One of the reasons I am considering the change is the power of the Prop would keep me from having to use multiple BS2 chips.
...but...but...that's where the FUN is!!!
http://www.youtube.com/watch?v=fkAkSHBwWQA
Main things that I can see missing off the bat are analog inputs and some of the handy basic commandds for PWM, pulse timing, and those sorts of things. The Object Exchange has some good stuff in there but finding it all can be a challenge. You can start in SPIN which is pretty easy and will blow away the BS2 in speed then move on to other languages like PASM/C/C++. I'm rewritting my robot code now for Martin Hodge's Propeller DNA board. It gives me 1MB of FLASH for the code. 32KB for instruction cache and data, an RTC and a built in uSD slot. QuickStart can also handle 64KB for code in C/C++ so it's pretty viable, cheap, and there are a growing ist of examples for it.
This narrows down the list of things you might consider studying.
For a general introduction, with emphasis on globally important issues, I personally like the Propeller education kit, in the 40 pin dip flavor.
But there are a lot of new users and potential new users reading the forum...all you would really have to do is pick a Prop board and then start asking questions:)
You will get all the help you need... and a lot of other people will be helped and/or encouraged to take the plunge.
Either way, please keep us informed of your progress.
Rich
Why not tell us a bit about the robot project?
Then we might be able to point you in the direction of already existing code that can be adapted.
