It all depends on the PLC and its serial ports. Some have RS232 capabilities; some, RS422; others RS485. The first two are full-duplex, so you would only need voltage translators to interface them to the XBee. RS485 is half-duplex, so the connection would be much less straightforward. Which PLC are you using?
