SMD Capacitor Type
I am developing a circuit board for a project and have used 0603 and 0805 capacitors, however I am now looking at getting the boards made up and buying the parts and I can't find these capacitors in the right values/types.
I need:
0603 - 0.1uF
0603 - 0.47uF
0805 - 10uF
I can get these in ceramic, however the schematics I used for reference show polarised capacitors and ceramic capacitors aren't.
The 10uF capacitors are for the power supply (input and output of a 3.3v regulator).
The 0.1uF and 0.47uF are for the power input (VDD/VSS) of the propeller chip and a BT module respectively.
Would ceramic capacitors work in this situation? Or can someone point me in the direction of the capacitors I need?
I need:
0603 - 0.1uF
0603 - 0.47uF
0805 - 10uF
kwinn: http://www.x-on.com.au/InventoryDetails.aspx?id=1083679&s=1 (0805 10uF 10volts X5R 10%)
For instance with Diptrace I use a Cap symbol polarized, so I have the cap polarity all around, even when not necessary.
I use a similar 10uF cap too (X7R 10uF 10V - mouser 81-GRM21BR71A106KE51)
A question about the format:
I've always used 0805 as form factor, because they are very easy to handle and solder. Moreover they fit nicely also on veroboards and perfboards.
What is your experience with 0603? I've never used them but I would like to give it a try.
Massimo
this is the same approach I use with 0805.
Massimo
But I still prefer 0805 as they are wider than tall and if I have to revork it due
to it standing up during reflow it's mush easier to put it back in place when it's a 0805.
0805 10uF
http://www.mouser.com/Search/ProductDetail.aspx?R=CC0805MKX5R5BB106virtualkey60120000virtualkey603-CC805MKX5R5BB106
