Stall Detection in A3697
I am using A3967 chip for driving stepper motor of 1.8 degree.
Is there any way that, when stepper motor stalls at the end of the operation or during the operation, the A3967 just shut off the output automatically.
Steppers are used when it is acceptable to assume that a certain number of pulses will get the motor to where its supposed to be.
In order to confirm that the motor actually got to where it was supposed to get, you will need some position feedback. That usually is an encoder, either buit into the motor or attached to the equipment being moved. The controller issues a command to move then watches the encoder to make sure the action was successfully completed.
A servo system (not usual hobby servo) has continuous position feedback at all times but is a more expensive option.
Cheers,
Cheers,
