Problem connecting electret preamp to Prop
lardom
I want to build a circuit with two electret mics so I could experiment with finding the direction of a sound source. I learned that I couldn't match the built-in mic on the 'Demo board' so it seems the solution is to use breakout boards. My question is do I connect the breakout boards to an adc chip first? I've already destroyed a Prop pin because I connected it to an amplified mic output.
http://www.parallaxsemiconductor.com/sites/default/files/appnotes/AN008-SigmaDeltaADC-v1.0_0.pdf
From the pre-amp, the ADC is done via the sigma-delta technique.
