Need some help understanding interaction between 2 objects
I have 2 obejects- Main_Test and Object2.
In the Main_Test object it runs a loop waiting for a key press from PST.
In Object2 it initializes 4 outputs for led's (Quickstart board) and runs a simple loop flashing 1 led on / off.
What I am trying to do is turn on one of the remaining led's by using a call method from the Main_Test object called Remote_Led. But it doesn't work like I thought it should. I was expecting that when that method was called it would then call the method in Object2 and turn on the led.
Why doesn't this work?
Thanks.
Don
CON
_clkmode = xtal1 + pll16x ' Feedback and PLL multiplier
_xinfreq = 5_000_000 ' External oscillator = 5 MHz
MS_001 = 80_000_000 / 1_000
obj
term : "fullduplexserialdp_1"
other_object : "object2"
var
pub main | c
term.start(31, 30, %0000, 115_200) ' start terminal using PST
pause(500) ' pause for PST
term.str(@message1) ' display device name on reset
other_object.start
pause(500)
repeat
c := term.rxcheck
if (c => 0) ' anything in m->s buffer?
case c
"r" , "R":
reboot
"c":
remote_led
pub remote_led
other_object.remote
pub pause(ms) | t
t := cnt
repeat ms
waitcnt(t += MS_001)
dat
message1 byte "Testing for transfer data",0
LED4 = 19
LED3 = 18
LED2 = 17
LED1 = 16
obj
var
byte p
long Stack[256], cog
PUB Start
cog := cognew(main,@Stack)+1
pub main
dira[16..19]~~
pause(1000) ' 1 second delay
outa[16..19]~~
outa[16..19]~
repeat
test_loop
pause(1000)
outa[LED1]~
pause(1000)
pub Test_Loop
outa[LED1]~~
pub Remote
outa[LED3]~~
pause(1000)
outa[LED3]~
pub pause(ms) | t
t := cnt
repeat ms
dat
Thanks.
Don
You have two solutions. 1) In other_object, have a global variable that's set by Remote that main will use to change the LED's state. 2) Have other_object's Start method set DIRA so bits 16..19 are outputs. The actual I/O pins will be the logical or of OUTA in cog #0 with OUTA in cog #1.
It's long, too involved and lame, but it works.
Three objects...
FlagDemo2.spin - the main program (top object?)
QS_Buttons.spin - the button driver
FlagWatch.spin - watches to see what's happening.
QS_Buttons doesn't play with any LEDs. It scans the touchpads and returns a byte with bits set according to the touch pads.
I == pressed, 0 == not.
FlagDemo2 is the main guy. It starts the other two objects in different cogs.
Notice the start calls... it passes the ADDRESS of a place where stuff will be passed back.
Then it watches the Buttons byte to see if button 4 is set (Touch pad 4)
When that happens it sets FLAG to 1
and changes the LEDs that it uses (22 and 17)
FLAG == 0 LED 22 := 1
FLAG == 1 LED 17 := 1
FlagWatch sets LED 3 just to show it's running.
Then it watchs for FLAG ==1 to happen.
When it sees that, it swaps LEDs (15 and 23).
LED 15 ON for flag == 0
LED 23 ON for Flag == 1
So the action is at the extreme ends of the LED string.
There should be two LEDS on at a time (not counting the middle one),
and both on the same end. If not, somebody is messing up.
Like I said, long, involved and way lame, but I learned how it works here.
Maybe it will help?
CON { Flag_Demo.spin } _CLKMODE=XTAL2 _xinfreq = 5_000_000 VAR LONG MS001, Buttons, Flag OBJ button: "QS_Buttons" ' touchpad driver OBJ Fwatch: "Flag_Watch" ' other cog method PUB ButtonDemo | B ' local variables MS001 := CLKFREQ / 1_000 ' define 1 millisec button.start( @Buttons ) ' send address of Buttons Fwatch.start(@flag) Repeat if Buttons & |< 4 ' button 4 pressed? Flag := 1 ' set Flag TurnON(4+16) ' show the button pressed WaitMS(10) TurnOFF(4+16) else Flag := 0 ' else clear Flag If Flag == 1 ' this cog can see Flag directly TurnON(1+16) ' LED 1 ON TurnOFF(6+16) ' LED 6 Off else TurnOFF(1+16) ' LED 1 OFF TurnON (6+16) ' LED 6 ON PUB WaitMS(W) ' wait for W milliseconds W := W*MS001 WaitCNT (W+cnt) PUB TurnON(pin) dira[pin] := 1 outa[pin] := 1 PUB TurnOFF(pin) dira[pin] := 1 outa[pin] := 0CON { Flag_Watch.spin } VAR LONG Stack[ 16 ] ' define my stack LONG FlagA, AcogID PUB start( F ) ' start this in a new cog FlagA := F ' save location of flag variable if ACogID cogstop(ACogID-1) ' no cog available ACogID := cognew(Aproc, @Stack) + 1 PUB Aproc 'main loop - scan the buttons Repeat ' loop forever TurnON(19) ' LED 3 show's I'm alive if byte[FlagA] == 1 'if I see a 1 TurnON(16) ' show this LED 15 TurnOFF(23) else 'if I see a 0 TurnON(23) ' show that LED 23 TurnOFF(16) PUB TurnON(pin) dira[pin] := 1 outa[pin] := 1 PUB TurnOFF(pin) dira[pin] := 1 outa[pin] := 0'CON { QS_ButtonScan.spin } ' { returns buttons packed bitwide is a byte} VAR LONG ButtonAdr, ButtonCog, MS001 LONG Stack[ 16 ] ' define my stack PUB start( BAdr ) ' BAdr = Button Address ButtonAdr := BAdr ' save address of return byte if ButtonCog ' did the new cog start? cogstop(ButtonCog-1) ' OOPS! no cog available ButtonCog := cognew(ButtonScan, @Stack) + 1 MS001 := clkfreq/1000 PUB ButtonScan | B, B1 ' local variables dira [0..7] := 111111 ' all pad pins outputs outa [0..7] := 111111 ' all pad pins high 'main loop - scan the buttons Repeat ' loop forever Repeat B from 0 to 7 ' QS LEDS are pins 0-7 dira [B] := 1 ' make pin an output dira [B] := 0 ' make pin an input WaitMS(4) ' short delay for some decay B1 := ina[B] ' read the pad if B1 == 0 ' 0 here means pressed BYTE[ButtonAdr] |= |< B ' set bit if pressed else BYTE[ButtonAdr] &= !|< B ' clear bit if not PUB WaitMS(W) 'wait for W milliseconds W := W * 1000 'MS001 WaitCNT (W+cnt)The code works (just checked it again) so if something is unclear, read
the code!
Now, I have a question...
I call fwatch.start to start the flag watch method.
But I didn't call the mainpart of the code (Aproc in Flag_Watch.spin).
And yet it works correctly.
Same thing with Button.Start.
Never called the ButtonScan method.
But it runs.
Why is that?
Is there something special aboutthe .start?
PUB start( BAdr ) ' BAdr = Button Address ButtonAdr := BAdr ' save address of return byte if ButtonCog ' did the new cog start? cogstop(ButtonCog-1) ' OOPS! no cog available ButtonCog := cognew([COLOR="red"]ButtonScan[/COLOR], @Stack) + 1 MS001 := clkfreq/1000So there is nothing to worry about.Thank you for kindly pointing out the painfully obvious which I completely missed when I was looking a the code tonight...
I remember now. I knew it couldn't fall though the end of the PUB or PRI block.
But I didn't catch the call inside the .start methods.
(The COGNEW did it - in the library - with a soldering iron... (anybody here old enough to get that?))
And the other one is invoked in its' .start function...
A lot of my learning so far has been pretty much cook-book style.
But eventually the LED comes on...
