How many Prop chips have YOU burnt out?
I've gone through three in the past few days and I'm wondering if that's an unusually high number when trying to learn? I'm hoping I'm on par and not a complete doofus LOL
How many did y'all burn out when goofing around?
Unless you are not wiring up all your power pins correctly or majorly abusing the other pins.
Three in a few days sounds a little unfortunate. What kind of goofing around were you doing?
Cheers
Richard
OUCH!
@ GeeksGoneBad
Yes, you are doing something MAJOR bad. Is this on a breadboard, wrong wiring, power wire backwards, etc.? I have never lost one. Maybe lucky, or careful. A miswire can only take a short moment after power is applied to cause something to GO.
No caps can render the PLL circuit inoperable. Non reversible.
More info would be helpful. A picture is worth 1000 words, but a schematic is worth millions...
Did cut some traces on a protoboard late one night. Felt stupid for working on a project at 3am, half-asleep.
OBC
Clearly my fault always.
I am a hardware builder, mostly on plugboards.
All were executed when high voltage got to the wrong place.
For what I do this seems about right. Part of doing business.
BTW, once something is built I haven't had any failures.
The 3 in a row, not good, unplug the chip and test before putting
another back, Otherwise it can get expensive.
Duane J
None --
And I uses extensive Over-clocking.
Test all PCBs I made for Bill Henning -- that needs often change place of Propeller from one PCB to other.
And Over-clocking in wide spectra of frequency.
My workhorse -- PROPELLER DEMO REV C 2006 -- runs like a champ.
The On/Off switch is a takes a tender touch though.
Considering I engineer about 10 new products a year, I would say I am overdue.
Do I bother you pushing that AUTODOC-thing of you here in those foras? I really like it ...
and, hmm, never burnt a prop. Stepped on one and bend all those pins.
Enjoy!
I am amazed that I have not killed others as I have done some weird things on my prototypes.
Like Sapeiha, I almost always overclock to 104 MHz.
Now that's cheating!
OBC
0, but not for lack of trying.....
Maybe when the curve tracer comes off the back burner.
FF
I've been amazed they just run and run. I've left them out running complex code for months between code changes and seen amazing reliability. I've gotten them to do a lot of complex and amazing things. I make my own boards and having worked with TTL and various uProcs over the years then I'm comfortable designing, building, debugging and troubleshooting things. I've had my share of problems to troubleshoot like the common "no propeller chip detected on any port", but this is a relatively simple problem to troubleshoot using a logic probe. An example the wife was cleaning our bedroom and accidentally knocked a running platform off the bedside table, still ran but couldn't be detected for loading code, turned out to be a hairline fracture in a surface mount cap. I have had props that appeared to crash, but it turned out to be bad power supply circuits, not the prop. When I thought this was an issue I got it to run the most basic code to flash a led to give me confidence that the chip had basic functionality before pushing up the code again, turned out when you have all 8 cores running it uses more current and stretches the power supply leading to the problem.
I've read earlier in the forum that in some rare circumstances folks have killed the internal PLL by not using decoupling caps on the power rails. They could still get it to load code and run on the internal clock, just not the external XTAL. I suspect that they probably didn't have a strong ground track between all of the prop's ground pins and may have had a set floating. The learning from this is four fold. 1. Connect all power pins. 2. Connect them together. 3. Use decoupling caps on all input power pins. 4. Understand how to take the prop back to the minimum baseline for troubleshooting.
In general, if you give it strong clean 3.3v, use decoupling caps on every set of power pins, have a good solid ground and don't over voltage or overdrive (too much drain current) the I/O pins, then they seem to be auite indestructible and amazingly stable workhorses (8 of them).
This may sound stupid, but what does dead mean? How do you know it's dead?
(if this is "propeller not found on any port then this may not be a bad prop and can be a fault in the circuitry for reset handshaking and the prop replying).
Please tell us know what you did.
This Prop was the fastest one too, D'oh!
Can we ask exactly what your set up was to yield so many in a short time? Not that I want to duplicate your results, I would like to know what to avoid.
And it would be helpful to arrive at your "doofus" evaluation request.
