Software solution to unwanted propeller reset using FullDuplexSerial?
Oldbitcollector (Jeff)
I'm curious (and Google isn't yielding an answer)
if there is a software solution to the Propeller resetting when a serial connection is closed on the PC?
OBC
OBC
Most of the code I stole from RossH's Catalina Loader called Payload.
BUT does NOT work with linux, still resetting there.
So I went back to ProtoBoards and PropPlug, short servocable inbetween and Reset not connected.
The other Reset-thing is solvable ...
mparks spinx is checking if pin 31 is high.
if yes Fullduplexserial gets started else not
this helps against a prop resetting itself using the port with usbcable disconnected.
w/o usb-onbord this problem does not exist.
Enoy!
