Eddie Control via Linux system
The intent in my project is to obtain and send information to the control board Eddie through a Linux system. No need to use Microsoft Robotics Developer Studio 4 (RDS4).
Typically, in the windows, would use a driver and/or a library of functions to make the USB connection to a control board.
In Linux, how will this connection?
Could someone give me a hint or point to a path?
Thank you for listening.
- Linux version: Ubuntu 10.04;
- Linux running on a notebook;
This is a drive to be studied.
I will also be looking at other possibilities.
Once you have the name of the COM port, Eddie is controlled via some simple text messages called the Eddie Command Set which are easy to parse which are documented in the linked PDF. You can write your own 'driver' for Eddie by talking to the COM port and sending/receiving these messages.
You'll still have to find yourself a programming environment on Linux that supports talking to the COM port. You have a couple of choices, such as C/C++, nodejs, or python.
I've attached a file that uses Python to connect to the serial port. It's a little messy, but shows a simple and cross platform programatic access method.
Here is how I develop for the Propeller on Ubuntu, if it helps: http://forums.parallax.com/showthread.php?140139-Gedit-Spin-Syntax-Highlighting-gt-Solution!&p=1098762#post1098762
#!/usr/bin/python #TODO Find out why there is a 1 being sent through serial from threading import Thread from threading import Lock import time import serial import platform import threading ser = None rx_buffer_lock = Lock() rx_buffer = [] thread = Thread() #last_received = '' class RxParser(object): def match(self, line, code): # Line is the received line from the rx_buffer # code is the string type that you want to match against, eg "$ADRPS" or "$ADMIA" original_line = line if line.find(code) != -1: #String matches line = line[len(code)+2:] #Get rid of found string. +2 to account for space and to get to next char nums = line.split(",") if len(nums) > 5: print "Bad datal. Too many fields." return [] try: for i in range(len(nums)): if i != 0: #Get rid of clock (for now, debug) # nums[i-1] = float(nums[i-1]) # TODO: FIX THIS TO ENABLE TIMING nums[i-1] = float(nums[i]) nums.pop() #Get rid last (non converted) string element (since the first space was occupied by the clock, but now holds a variable value) except ValueError: print "RxParser: Could not parse ", code, " String. RX Line: ", original_line return [] return nums else: return [] # def ADRPS(self, line): # #Returns a list with the motor speeds, or an empty list # if line.find("$ADRPS ") != -1: #String matches # line = line[8:] #Get rid of found string # nums = line.split(",") # try: # for i in range(len(nums)): # nums[i] = float(nums[i]) # except ValueError: # print "Could not parse $ADRPS String" # return [] # # return nums # else: # return [] # def ADMIA(self, line): # #Returns a list with the motor currents, or an empty list # if line.find("$ADMIA ") != -1: #String matches # line = line[8:] #Get rid of found string # nums = line.split(",") # try: # for i in range(len(nums)): # nums[i] = float(nums[i]) # except ValueError: # print "Could not parse $ADMIA String" # return [] # # return nums # else: # return [] def receiving(ser): global rx_buffer global threadkillall # global threadkillall buffer = '' # while not threadkillall: while True: buffer = buffer + ser.read(ser.inWaiting()) if '\n' in buffer: lines = buffer.split('\n') # Guaranteed to have at least 2 entries # print "len(lines) == ", len(lines) if not rx_buffer_lock.acquire(False): # print "Could not get lock..." pass else: # print "Got lock..." try: for i in range(len(lines)-1): rx_buffer.append(lines[i]) # last_received = lines[-2] finally: rx_buffer_lock.release() #If the Arduino sends lots of empty lines, you'll lose the #last filled line, so you could make the above statement conditional #like so: if lines[-2]: last_received = lines[-2] buffer = lines[-1] else: time.sleep(.01) print "closing..." ser.close() def sending(ser, command): global rx_buffer global threadkillall #whatwas = 1 #sersend.open() print ser.isOpen() print ser.portstr print str(command) + "\n" ser.write(str(command)+ "\n") whatwas=2 #ser.write("hello") whatwas=3 time.sleep(.01) print whatwas class DataGen(object): def __init__(self, init=50): try: if platform.system() == 'Windows': global ser ser = serial.Serial( port = 'COM24', baudrate=115200, # bytesize=serial.EIGHTBITS, # parity=serial.PARITY_NONE, # stopbits=serial.STOPBITS_ONE, # timeout=0.1, # xonxoff=0, # rtscts=0, # interCharTimeout=None ) else: global ser ser = serial.Serial( # port = '/dev/ttyUSB0', port = '/dev/ttyACM0', baudrate=115200, # bytesize=serial.EIGHTBITS, # parity=serial.PARITY_NONE, # stopbits=serial.STOPBITS_ONE, # timeout=0.1, # xonxoff=0, # rtscts=0, # interCharTimeout=None ) except serial.serialutil.SerialException: #no serial connection ser = None print "NO Serial Connection! Check Serial Port! Closing." else: thread2 = threading.Thread(target=sending, args=(ser,'',)).start() thread = threading.Thread(target=receiving, args=(ser,)).start() # def next(self): # if not self.ser: # return 100 #return anything so we can test when Propeller isn't connected # #return a float value or try a few times until we get one # return 50 # # for i in range(40): # raw_line = last_received # try: # return float(raw_line.strip()) # except ValueError: # print 'bogus data',raw_line # time.sleep(.5) # return 0. def cleanup(): print "Ending and cleaning up" thread.exit() if __name__=='__main__': print "Please note this is not intended to be run standalone. Please run ./anzhelka_terminal_gui.py instead." s = DataGen() while True: time.sleep(.015) print s.next()
