asm pixel filler using graphics object problems
HYDRA not demo board.
playing with the graphics demo stuff stripped down
more like pixel xoring
I've been playing on and off for about 9 hours or so...since 6pm. Finally admitting defeat and asking for help.
padded nops in thinking it was a hub problem, I heard about flag propagation delays on the oled prop, maybe my props just going bad, shorted pins, dirty board, I just dont know. Tried a different 9v wall adapter, same results
Hopefully a keen eye can spot what I'm doing wrong.
my comments try to tell what I want the statements to do, unless I have a big misconception of asm
I've tried going pllx4 still doesn't work,
I am trying to do:
xor graphic longs left to right on screen top to bottom like a type writer would
I know the graphics memory layout is top to bottom then left to right.
as you increment you are going down screen until you pop back up at the top and over a column.
in 4x3 tiles 64x48 pixels video mode stretched out to make nice big blocks I can see the pixels flickering, but only one row, 64x1
I understand my yloop needs to be 16x greater cause there are 16longs per tile, but that is the problem. yloop'ing is when it crashes.
if I set my yloop counter "yl" to more than 1 it crashes on would really love some help if anybody wants to copy/paste this to their hydra or demo board(pin changes?)
I am trying to do:
CON
_clkmode = xtal1 + pll4x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 10_000_000
_stack = ($3000 + $3000 + $64) >> 2
' graphics driver and screen constants straight from the book,
PARAMCOUNT = 14
OFFSCREEN_BUFFER = $2000
ONSCREEN_BUFFER = $5000
' size of graphics tile map
X_TILES = 4
Y_TILES = 3
SCREEN_WIDTH = X_TILES * 16
SCREEN_HEIGHT = Y_TILES * 16
' color constant's to make setting colors for parallax graphics setup easier
COL_Black = %0000_0010
COL_DarkGrey = %0000_0011
COL_Grey = %0000_0100
COL_LightGrey = %0000_0101
COL_BrightGrey = %0000_0110
COL_White = %0000_0111
'color values
COL_PowerBlue = %0000_1_100
COL_Blue = %0001_1_100
COL_SkyBlue = %0010_1_100
COL_AquaMarine = %0011_1_100
COL_LightGreen = %0100_1_100
COL_Green = %0101_1_100
COL_GreenYellow = %0110_1_100
COL_Yellow = %0111_1_100
COL_Gold = %1000_1_110
COL_Orange = %1001_1_100
COL_Red = %1010_1_100
COL_VioletRed = %1011_1_100
COL_Pink = %1100_1_100
COL_Magenta = %1101_1_100
COL_Violet = %1110_1_100
COL_Purple = %1111_1_100
COLOR_0 = (COL_Black << 0)
COLOR_1 = (COL_Green << 8 )
COLOR_2 = (COL_SkyBlue << 16 )
COLOR_3 = (COL_Gold << 24 )
VAR
long tv_status '0/1/2 = off/visible/invisible
long tv_enable '0/? = off/on
long tv_pins '%ppmmm= pins
long tv_mode '%ccinp = chroma, interlace, ntsc/pal, swap
long tv_screen 'pointer to screen (words)
long tv_colors 'pointer to colors (longs)
long tv_hc 'horizontal cells
long tv_vc 'vertical cells
long tv_hx 'horizontal cell expansion
long tv_vx 'vertical cell expansion
long tv_ho 'horizontal offset
long tv_vo 'vertical offset
long tv_broadcast 'broadcast frequency (Hz)
long tv_auralcog 'aural fm cog
word screen[X_TILES * Y_TILES]
long colors[64]
long randomcolor
long cogparams[32]
OBJ
tv : "tv"
gr : "graphics"
'ser : "Parallax Serial Terminal"
PUB start | i, dx, dy, x, y
'start tv
longmove(@tv_status, @tvparams, paramcount)
tv_screen := @screen
tv_colors := @colors
tv.start(@tv_status)
randomcolor := 65535
repeat i from 0 to 64
colors[i] := COLOR_3 | COLOR_2 | COLOR_1 | COLOR_0
'init tile screen
repeat dx from 0 to 31
cogparams[dx] := 0
repeat dx from 0 to tv_hc -1
repeat dy from 0 to tv_vc -1
screen[dy * tv_hc + dx] := onscreen_buffer >> 6 + dy+dx*tv_vc+((dy&$3f) <<10 )
gr.start
gr.setup(X_TILES,Y_TILES,0,0, onscreen_buffer)
cogparams[0] := @cogparams
cogparams[1] := 2 'x
cogparams[2] := 2 'y
cogparams[3] := Y_TILES * 16 * 4 'number of longs
cognew(@cog,@cogparams)
repeat while true
gr.clear
repeat dx from 0 to SCREEN_WIDTH - 1
repeat dy from 0 to SCREEN_HEIGHT - 1
i := (?randomcolor) & $0000_0003
gr.colorwidth(i,0)
gr.plot(dx,dy)
PRI private_method_name
DAT
tvparams long 0 'status
long 1 'enable
long %011_0000 'pins
long %0000 'mode
long 0 'screen
long 0 'colors
long x_tiles 'hc
long y_tiles 'vc
long 40 'hx timing stretch
long 4 'vx
long 0 'ho
long 0 'vo
long 0 'broadcast on channel 2 vhf
long 0 'auralcog
long 0
long 0
dat
org 0
cog mov t1, par
mov t3,#4 '4 pars
get_pars rdlong log, t1
add get_pars,d0 'inc source
add t1,#4 'inc dest
djnz t3,#get_pars 'get next par
mov log,par
init_loop
mov yp,base_ptr 'reset yp to top of video memory
mov xl,#3 'reset xloop counter
mov yl,#1 'reset yloop counter
yloop mov xp,yp 'reset xpointer to current ypointer
xloop rdlong t2,xp 't2 is data, xl is xloop counter
xor t2,allset 'xor it
wrlong t2,xp 'store it
add xp,col_add 'go over a column
djnz xl,#xloop 'do it again
'yloop post
add yp,#4 'go down a row
djnz yl,#yloop 'do it again
jmp #init_loop
'djnz timeout,#init_loop
cogid cid
cogstop cid
d0 long $200
highword long $FFFF_0000
lowword long $0000_FFFF
allset long $FFFF_FFFF
zero long $0000_0000
base_ptr long onscreen_buffer
timeout long 5_000_000
t1 res 1 '
t2 res 1 '
t3 res 1 '
xp res 1 'xpointer
yp res 1 'ypointer
xl res 1 'xloop counter
yl res 1 'yloop counter
'PARS
log res 1 'feedback/command
xcount res 1 'xloops
ycount res 1 'yloops
col_add res 1 'Y_TILES*16*4, number of longs in a vertical column on screen
cid res 1 'cogid
mov yl,#1 'reset yloop counter yloop mov xp,yp 'reset xpointer to current ypointer mov xl,#3 'reset xloop counterGreat reply! You let me know exactly what I was doing, not what I thought I was doing. Let me figure out how to change what it does, to what I want it to do!
I was doing 64k-1 horizontal pixels the next yloop!
the whole night I was sitting there thinking, "The top of every loop must initialize the next inner loop" but missed that.
but I wasn't fixing the inner inner loop, xloop thanks for the quick reply! I knew it had to be something simple. I was this close to "stepping through" it on paper following my DECs and ADDs.
*edit* just moved the line down and it works! now I can go back to my "bigger" program and look for the same mistake.
I think he dreams in PASM...
