Propeller Powered Power Supply
I'm almost done coding the Propeller, which I will use in the power supply I'm making. The Propeller will measure and display voltage (using voltage synthesis via a counter module, and a comparator), measure and display current (using a shunt), and the Prop will control the soft-start circuitry. I will have around 4 open cogs and 6 I/Os left, so what should I do with the extra processing power?
