problem getting value from INA
                    I wrote this routine, the serial portion works just fine. I'm having problems getting a value from an input pin. I don't think the problem is in the code, but I'll paste it below anyway. On the propeller board I have an input pin connected to ground with a 200 ohm resistor and a another 200 ohm resistor connected to 3.3V that I use to 'turn on' the input pin. On the serial monitor I keep getting 0's. And it's quite annoying.
(edit) -I have tried using smaller resistors on one or the other side, I know 200 across 200 ohms is going to give 1.15V
                            CON
  _clkmode = xtal1 + pll4x
  _xinfreq = 6_000_000
PUB Main
  cognew(@IR,0)
Dat
org 0
IR
:initialization
              or        dira,tx
              or        outa,tx
:receive
              waitpne   rx,rx
              mov       time,delay
              add       time,cnt
              waitcnt   time,delay
:getData
              test      ina,dIn wc
        if_c  mov       data,#49
        if_nc mov       data,#48
:readyData
              mov       tx_dat,data            'sample first byte of data
              or        tx_dat,#$100           'attach stop bit
              shl       tx_dat,#$1              'shift left to assign start bit
              mov       nBits,#10              'total number of bits for serial byte is equal to 10 - send that many
:txLoop
              ror       tx_dat,#1 wc
              muxc      outa,tx
              djnz      nBits,#:txLoop
              jmp       #:getData
dIn           long $0000_8000
tx            long $4000_0000
rx            long $8000_0000
delay         long 120
time          res 1
data          res 1
tx_dat        res 1
nBits         res 1
