Suggestions needed for parts selection on a high-speed PIN photodiode circuit
I had some unused space on a recent PCB I had sent out, so on a lark I hastily filled up that space with a circuit I got from Example #6 of this document:
http://sales.hamamatsu.com/assets/applications/SSD/si_pd_circuit_examples.pdf
I've never tinkered with a circuit like this, so I have no idea what the values for R, Rf, RL should be. And I'm just guessing that the V in the equation refers to the voltage of the amp's power input, but I don't really know. The PIN photodiode I just so happen to have laying around is the following:
http://www.vishay.com/docs/81502/bpv10.pdf
Anyway, I'd like to play with this circuit and I need to order the parts. I'm interested in using the circuit to detect flashes of IR, though I don't really know how intense they will be. At this stage, I'm just goofing around with it, but I'd appreciate some suggestions on some ballpark numbers for the R's and such.
Much obliged.
Much obliged.
Lawson
I'm thinking each pulse could be as short as maybe around 5 micro seconds, each pulse spaced by at least 100 usec. Thanks for the insight into the effective low-pass filter. Any ballpark suggestions for what components I might try?
O Tracy. O, brother, where art thou?
Duane J
Hi Duane, thanks for your interest.
To be honest, I don't have any idea of the light intensity. I just wanted to put one of these circuits together to play with and I don't even know where to start sizing the components. Is there some way to at least guess what the range of the various R's might/should be?
FYI, Tracy has been helping me out with my attempt to use a photodiode as a light sensor. Maybe some of his advice to me will help you.
Those TAOS light to frequency chips sure make sensing light a lot easier than using a bare photodiode.
Interesting. I'll have to look through all of that excellent material and see what I can learn. Thanks!
Yes, I love the TAOS chips, but they suck when you're trying to "integrate" a number of very bright pulses - I think they can saturate during a short bright pulse and give you readings that trick you into thinking that the pulsed light integrated over time is smaller than it actually is. See my old whine:
http://forums.parallax.com/showthread.php?133699-How-fast-bright-flashes-can-cause-errors-in-the-TSL230-Light-to-Frequency-sensor
If you truly are trying to measure a pulse, example #13 might be more useful. It's output voltage in proportional to how much energy has hit the photo-diode since the last reset. It'll let you make one ADC measurement after the pulse arrives, instead of having to catch the pulse at it's peak or record the pulse shape.
Lawson
Lawson,
thanks very much for your insights on this. I guess by just jumping into making one of these PIN circuits, I was hoping to force myself to learn what's actually going on inside one. Your comments have been very helpful.
The circuit is simple enough and allows for experimentation. Go for it! If you have a good 'scope, that will be your readout. Figure the current from the PIN diode is going to be on the order of 1 µA to 100 µA, so RL=1kΩ and an amplifier gain of x10 will give you a signal that the 'scope can see. Point a flashing light (Prop controlled of course) at the photodiode and see what the output signal looks like. Then play with the component values to improve the sensitivity and/or the speed.
The subject is fraught with tradeoffs of speed, noise, sensitivity etc. etc. The most interesting reference that I keep coming back to is a book by Phil Hobbs, Building Electo-Optical Systems; Making it All Work. It is full of all sorts of lore and practical information and circuits (but bring your own glossary).
Linear Tech has some interesting photodiode ideas in their circuit collections.
Tracy, thanks so much for pointing me to these references and providing some great clues. It's just the sort of thing I needed to get started.
@Tracy: that Linear tech application note reminds me of www.electrooptical.net/www/frontends/frontends.pdf from the same author as the book you suggested.
Lawson
Excellent stuff. Thanks again, Lawson. But, man, that's some amazing intuition those people must be sportin'.
