Spinneret *Timeout* — Parallax Forums
Spinneret *Timeout*
PodionPodion Posts: 90
edited 2012-08-20 10:26 in Propeller 1
Hello all
I plug my spinneret on the internet and there is some mistake.
When I access the server 24.230.203.105:5555 with WiFi I have no problem. But when I use another internet connection that does not work at all or it works half the time. Have you any idea?
I try to access the server with my iPhone 4 and it works well with WiFi connection but nothing to do with the cellular network. It still gives the same error. * Timeout * Do you know why?
There is the PST message
Start of Request
Request Count : 16
3-14 2-14 1-14 0-18
clsd open lstn estb clwt clng udps
0000-0000-1110-0001-0000-0000-0000
FIFO[0] 00000000
* Timeout *
There is the code i use
Copyright (c) 2011 AgaveRobotics LLC.
See end of file for terms of use.
File....... HTTPServer.spin
Author..... Mike Gebhard
Company.... Agave Robotics LLC
Email...... mailto:mike.gebhard@agaverobotics.com
Started.... 11/01/2010
Updated.... 07/16/2011
About:
  HTTPServer is the designed for use with the Spinneret Web server manufactured by Parallax Inc.
Usage:
  HTTPServer is the top level object.
  Required objects:
        • Parallax Serial Terminal.spin
        • W5100_Indirect_Driver.spin
        • S35390A_SD-MMC_FATEngineWrapper.spin
        • Request.spin
        • Response.spin
        • StringMethods.spin
        • S35390A_RTCEngine.spin
Change Log:
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  MAX_PACKET_SIZE = $5C0 '1472   '$800 = 2048
  RxTx_BUFFER     = $800         '$600 = 1536
  TEMP_BUFFER     = $600         '$5B4 = 1460
  TCP_PROTOCOL    = 01        '$300 = 768
  UDP_PROTOCOL    = 10        '$200 = 512
  TCP_CONNECT     = $04          '$100 = 256
  DELAY           = $05
  MAX_TRIES       = $05
  #0, DONE, PUT, CD
DAT
  mac                   byte    $00, $08, $DC, $16, $F2, $73
  subnet                byte    255, 255 ,255, 0
  gateway               byte    24,230,203,1
  ip                    byte    192,168,0,105
  port                  word    5555
  remoteIp              byte    24,230,203,105
  remotePort            word    80
  uport                 word    5050
  emailIp               byte    0, 0, 0, 0
  emailPort             word    25
  status                byte    $00, $00, $00, $00
  rxdata                byte    $0[RxTx_BUFFER]
  txdata                byte    $0[RxTx_BUFFER]
  udpdata               byte    $0[TEMP_BUFFER]
  fileErrorHandle       long    $0
  debug                 byte    $0
  lastFile              byte    $0[12], 0
  closedState           byte    00
  openState             byte    00
  listenState           byte    00
  establishedState      byte    00
  closingState          byte    00
  closeWaitState        byte    00
  lastEstblState        byte    00
  lastEstblStateDebug   byte    00
  udpListen             byte    00
  tcpMask               byte    11
  udpMask               byte    00
  fifoSocketDepth       byte    $0
  fifoSocket            long    $00_00_00_00
  debugSemId            byte    $00
  debugCounter          long    $00
  stringMethods         long    $00
  closingTimeout        long    $00, $00, $00, $00
  udpLen                long    $00
  time                  byte    "00/00/0000 00:00:00", 0
  httpDate              byte    "Wed, 01 Feb 2000 01:00:00 GMT", 0
  globalCache           byte    $0
VAR
  long StackSpace[20]
OBJ
  pst           : "Parallax Serial Terminal"
  Socket        : "W5100_Indirect_Driver"
  SDCard        : "S35390A_SD-MMC_FATEngineWrapper"
  Request       : "Request"
  Response      : "Response"
  str           : "StringMethods"
  rtc           : "S35390A_RTCEngine"
PUB Initialize | id, size, st
  debug := 1
  SDCard.Start
  stringMethods := str.Start
  Request.Constructor(stringMethods)
  Response.Constructor(stringMethods, @txdata)
  pst.Start(115_200)
  pause(200)
  'Mount the SD card
  pst.str(string("Mount SD Card - "))
  SDCard.mount(fileErrorHandle)
  pst.str(string("OK",13))
  pst.str(string("Start RTC: "))
  rtc.RTCEngineStart(29, 28, -1)
  pause(200)
  pst.str(FillTime)
  'Start the W5100 driver
  if(Socket.Start)
    pst.str(string(13, "W5100 Driver Started", 13))
    pst.str(string(13, "Status Memory Lock ID    : "))
    pst.dec(Socket.GetLockId)
    pst.char(13)
  if(debugSemId := locknew) == -1
    pst.str(string("Error, no HTTP server locks available", 13))
  else
    pst.str(string("HTTP Server Lock ID      : "))
    pst.dec(debugSemId)
    pst.char(13)
  'Set the Socket addresses
  SetMac(@mac)
  SetGateway(@gateway)
  SetSubnet(@subnet)
  SetIP(@ip)
  ' Initailize TCP sockets (defalut setting; TCP, Port, remote ip and remote port)
  repeat id from 0 to 3
    InitializeSocket(id)
    Request.Release(id)
    pause(50)
  ' Set all TCP sockets to listen
  pst.char(13)
    Socket.Listen(id)
    pst.str(string("TCP Socket Listener ID   : "))
    pst.dec(id)
    pst.char(13)
    pause(50)
  pst.Str(string(13,"Started Socket Monitoring Service", 13))
  cognew(StatusMonitor, @StackSpace)
  pause(250)
  pst.Str(string(13, "Initial Socket States",13))
  StackDump
  pst.Str(string(13, "Initial Socket Queue",13))
  QueueDump
  pst.str(string(13,"//////////////////////////////////////////////////////////////",13))
  Main
PUB Main | packetSize, id, i, reset, j, temp
  ''HTTP Service
  repeat
    repeat until fifoSocket == 0
      bytefill(@rxdata, 0, RxTx_BUFFER)
      if(debug)
        pst.str(string(13, "----- Start of Request----------------------------",13))
        pause(DELAY)
      else
        pause(DELAY)
      ' Pop the next socket handle
      id := DequeueSocket
      if(id < 0)
        next
      if(debug)
        pst.str(string(13,"ID: "))
        pst.dec(id)
        pst.str(string(13, "Request Count     : "))
        pst.dec(debugCounter)
        pst.char(13)
      packetSize := Socket.rxTCP(id, @rxdata)
      reset := false
      if ((packetSize < 12) AND (strsize(@rxdata) < 12))
        repeat i from 0 to MAX_TRIES
           'pst.str(string(13,"* Retry *"))
          'Wait for a few moments and try again
          waitcnt((clkfreq/500) + cnt)
          if(packetSize > 12)
            quit
          if(i == MAX_TRIES)
            'Clean up resource request
            Request.Release(id)
            Socket.Disconnect(id)
            reset := true
            if(debug)
              StackDump
              pst.char(13)
              QueueDump
              pst.str(string(13,"* Timeout *",13))
      if(reset)
        next
      Request.InitializeRequest(id, @rxdata)
      if(debug)
        pst.char(13)
        HeaderLine1(id)
      else
        pause(DELAY)
      ' Process router
      Dispatcher(id)
      'Clean up request resource
      Request.Release(id)
      ' This starts the close process -> 0x00
      ' use close to force a close
      bytefill(@txdata, 0, RxTx_BUFFER)
      debugCounter++
  GotoMain
PRI GotoMain
  Main
PRI Dispatcher(id)
  ''Do some processing before sending the response
  if(strcomp(Request.GetName(id), string("led")))
    Led(id)
  StaticFileHandler(id)
  return
PRI Led(id) | qstr
  '' Get the query string value
  qstr :=  Request.Get(id, string("led"))
  if (strcomp( string("on"), qstr ))
    LedStatus(1)
  else
    LedStatus(0)
  return
PRI LedStatus(state)
  dira[23]~~
  outa[23] := state
  return
PRI StaticFileHandler(id) | fileSize, i, headerLen, temp, j
  ''Serve up static files from the SDCard
  'pst.str(string(13,"Static File Handler",13))
  SDCard.changeDirectory(@approot)
  pst.char(13)
  'Make sure the directory exists
  ifnot(ChangeDirectory(id))
    'send 404 error
    WriteError(id)
    return
  ' Make sure the file exists
  ifnot(FileExists(Request.GetFileName(id)))
    'send 404 error
    WriteError(id)
    return
  ' Open the file for reading
  SDCard.openFile(Request.GetFileName(id), "r")
  fileSize := SDCard.getFileSize
  'WriteResponseHeader(id)
  'BuildHeader(extension, statusCode, expirer)
  headerLen := Response.BuildHeader(Request.GetExtension(id), 200, globalCache)
  Socket.txTCP(id, @txdata, headerLen)
  if fileSize < MAX_PACKET_SIZE
    ' send the file in one packet
    SDCard.readFromFile(@txdata, fileSize)
    Socket.txTCP(id, @txdata, fileSize)
  else
    ' send the file in a bunch of packets
    repeat
      SDCard.readFromFile(@txdata, MAX_PACKET_SIZE)
      Socket.txTCP(id, @txdata, MAX_PACKET_SIZE)
      fileSize -= MAX_PACKET_SIZE
      ' once the remaining fileSize is less then the max packet size, just send that remaining bit and quit the loop
      if fileSize < MAX_PACKET_SIZE and fileSize > 0
        quit
      ' Bailout
      if(i++ > 1_000_000)
        WriteError(id)
        quit
  SDCard.closeFile
  return
PRI WriteError(id) | headerOffset
  '' Simple 404 error
  pst.str(string(13, "Write 404 Error",13 ))
  headerOffset := Response.BuildHeader(Request.GetExtension(id), 404, false)
  Socket.txTCP(id, @txdata, headerOffset)
  return
'' directory and file handlers
PRI ChangeDirectory(id) | i, found
  'Handle directory structure for this Request
  if(Request.GetDepth(id) > 1)
    repeat i from 0 to Request.GetDepth(id)-2
      'Return if the directory is not found
      ifnot(FileExists(Request.GetPathNode(id, i)))
        return false
      found := SDCard.changeDirectory(Request.GetPathNode(id, i))
  return true
PRI FileExists(fileToCompare) | filenamePtr
'Start file find at the top of the list
  SDCard.startFindFile
  'Verify that the file exists
  repeat while filenamePtr <> 0
    filenamePtr := SDCard.nextFile
    if(str.MatchPattern(filenamePtr, fileToCompare, 0, false ) == 0 )
      return true
  return false
'' Time Methods and Formats
PRI GetTime(id) | ptr, headerOffset
  ptr := @udpdata
  FillHttpDate
  bytemove(ptr, string("<p>"),3)
  ptr += 3
  bytemove(ptr, @httpDate, strsize(@httpDate))
  ptr += strsize(@httpDate)
  bytemove(ptr, string("</p>"),4)
  ptr += 3
  headerOffset := Response.BuildHeader(Request.GetExtension(id), 200, false)
  StringSend(id, @udpdata)
  bytefill(@udpdata, 0, TEMP_BUFFER)
  return
PRI FillTime | ptr, num
 'ToString(integerToConvert, destinationPointer)
 '00/00/0000 00:00:00
  ptr := @time
  rtc.readTime
  FillTimeHelper(rtc.clockMonth, ptr)
  ptr += 3
  FillTimeHelper(rtc.clockDate, ptr)
  ptr += 3
  FillTimeHelper(rtc.clockYear, ptr)
  ptr += 5
  FillTimeHelper(rtc.clockHour , ptr)
  ptr += 3
  FillTimeHelper(rtc.clockMinute , ptr)
  ptr += 3
  FillTimeHelper(rtc.clockSecond, ptr)
  return @time
PRI FillHttpDate | ptr, num, temp
 'Wed, 01 Feb 2000 01:00:00 GMT
  ptr := @httpDate
  rtc.readTime
  temp := rtc.getDayString
  bytemove(ptr, temp, strsize(temp))
  ptr += strsize(temp) + 2
  ptr += 3
  temp := rtc.getMonthString
  ptr += strsize(temp) + 1
  ptr += 5
  ptr += 3
  ptr += 3
  return @httpDate
PRI FillTimeHelper(number, ptr) | offset
  offset := 0
  if(number < 10)
    offset := 1
  str.ToString(@number, @tempNum)
  bytemove(ptr+offset, @tempNum, strsize(@tempNum))
'' SDCard Logger
PRI AppendLog(logToAppend)
  '' logToAppend:  Pointer to a string of test we'd like to log
  if(FileExists(@logfile))
    SDCard.openFile(@logfile, "A")
  else
    SDCard.newFile(@logfile)
  SDCard.writeData(string(13,10,"----- Start "),14)
  SDCard.writeData(FillTime, 19)
  SDCard.writeData(string(" -----"),6)
  SDCard.writeData(@crlf_crlf, 2)
  SDCard.writeData(logToAppend, strsize(logToAppend))
  SDCard.writeData(string("----- End "),10)
  SDCard.closeFile
'' Memory Management
PRI Set(DestAddress, SrcAddress, Count)
  bytemove(DestAddress, SrcAddress, Count)
  bytefill(DestAddress+Count, $0, 1)
'' Socekt helpers
PRI GetTcpSocketMask(id)
  return id & tcpMask
PRI DecodeId(value) | tmp
    if(01 & value)
      return 0
    if(10 & value)
      return 1
    if(00 & value)
      return 2
    if(00 & value)
      return 3
  return -1
PRI QueueSocket(id) | tmp
  if(fifoSocketDepth > 4)
    return false
  tmp := |< id
  'Unique check
  ifnot(IsUnique(tmp))
    return false
  tmp <<= (fifoSocketDepth++) * 8
  fifoSocket |= tmp
  return true
PRI IsUnique(encodedId) | tmp
  tmp := encodedId & $0F
  repeat 4
    if(encodedId & fifoSocket)
      return false
    encodedId <<= 8
  return true
PRI DequeueSocket | tmp
  if(fifoSocketDepth == 0)
    return -2
  repeat until not lockset(debugSemId)
  tmp := fifoSocket & $0F
  fifoSocket >>= 8
  fifoSocketDepth--
  lockclr(debugSemId)
  return DecodeId(tmp)
PRI ResetSocket(id)
  Socket.Close(id)
PRI IsolateTcpSocketById(id) | tmp
  tmp := |< id
  tcpMask &= tmp
PRI SetTcpSocketMaskById(id, state) | tmp
'' The tcpMask contains the socket the the StatusMonitor monitors
  tmp := |< id
  if(state == 1)
    tcpMask |= tmp
  else
    tmp := !tmp
    tcpMask &= tmp
'' W5100 Helper methods
PRI GetCommandRegisterAddress(id)
  return Socket#_S0_CR + (id * $0100)
PRI GetStatusRegisterAddress(id)
  return Socket#_S0_SR + (id * $0100)
PRI SetMac(_firstOctet)
  Socket.WriteMACaddress(true, _firstOctet)
  return
PRI SetGateway(_firstOctet)
  Socket.WriteGatewayAddress(true, _firstOctet)
  return
PRI SetSubnet(_firstOctet)
  Socket.WriteSubnetMask(true, _firstOctet)
  return
PRI SetIP(_firstOctet)
  Socket.WriteIPAddress(true, _firstOctet)
  return
PRI StringSend(id, _dataPtr)
  Socket.txTCP(id, _dataPtr, strsize(_dataPtr))
  return
PRI SendChar(id, _dataPtr)
  Socket.txTCP(id, _dataPtr, 1)
  return
PRI SendChars(id, _dataPtr, _length)
  Socket.txTCP(id, _dataPtr, _length)
  return
PRI InitializeSocket(id)
  Socket.Initialize(id, TCP_PROTOCOL, port, remotePort, @remoteIp)
  return
PRI InitializeSocketForEmail(id)
  Socket.Initialize(id, TCP_PROTOCOL, port, emailPort, @emailIp)
  return
PRI InitializeUPDSocket(id)
  Socket.Initialize(id, UDP_PROTOCOL, uport, remotePort, @remoteIp)
  return
'' Debug/Display Methods
PRI QueueDump
  '' Display socket IDs in the queue
  '' ie 00000401 -> socket Zero is next to pop off
  pst.str(string("FIFO["))
  pst.dec(fifoSocketDepth)
  pst.str(string("] "))
  pst.hex(fifoSocket, 8)
PRI StackDump | clsd, open, lstn, estb, clwt, clng, id, ulst
  '' This method is purely for debugging
  '' It displays the status of all socket registers
  clsd := closedState
  open := openState
  lstn := listenState
  estb := establishedState
  clwt := closeWaitState
  clng := closingState
  ulst := udpListen
  lockclr(debugSemId)
  pst.char(13)
  repeat id from 3 to 0
    pst.dec(id)
    pst.str(string("-"))
    pst.hex(status[id], 2)
    pst.str(string(" "))
    pause(1)
  pst.str(string(13,"clsd open lstn estb clwt clng udps", 13))
  pst.bin(clsd, 4)
  pst.bin(open, 4)
  pst.bin(lstn, 4)
  pst.bin(estb, 4)
  pst.bin(clwt, 4)
  pst.bin(clng, 4)
  pst.bin(ulst, 4)
  pst.char(13)
PRI HeaderLine1(id) | i
  pst.str(Request.GetMethod(id))
  pst.char($20)
  i := 0
  repeat Request.GetDepth(id)
    pst.char($2F)
    pst.str(Request.GetPathNode(id, i++))
PRI Pause(Duration)
  waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt)
  return
PRI StatusMonitor | id, tmp, value
'' StatusMonitor is the heartbeat of the project
'' Here we monitor the state of the Wiznet 5100's 4 sockets
  repeat
    Socket.GetStatus32(@status[0])
    ' Encode status register states
    closedState := openState := listenState := establishedState := {
     } closeWaitState := closingState := 0
      case(status[id])
        $00: closedState               |= |< id
             closedState               &= tcpMask
        $13: openState                 |= |< id
             openState                 &= tcpMask
        $14: listenState               |= |< id
             listenState               &= tcpMask
        $17: establishedState          |= |< id
             establishedState          &= tcpMask
        $18,$1A,$1B: closingState      |= |< id
                     closingState      &= tcpMask
        $1C: closeWaitState            |= |< id
             closeWaitState            &= tcpMask
        $1D: closingState              |= |< id
        $22: udpListen                 |= |< id
             udpListen                 &= udpMask
    if(lastEstblState <> establishedState)
      value := establishedState
      repeat while value > 0
        tmp := DecodeId(value)
        if(tmp > -1)
          QueueSocket(tmp)
          tmp := |< tmp
          tmp := !tmp
          value &= tmp
      lastEstblState := establishedState
    lockclr(debugSemId)
    ' Initialize a closed socket
    if(closedState > 0)
      id := DecodeId(closedState)
      if(id > -1)
        InitializeSocket(id & tcpMask)
    'Start a listener on an initialized/open socket
    if(openState > 0)
      id := DecodeId(openState)
      if(id > -1)
        Socket.Listen(id & tcpMask)
    ' Close the socket if the status is close/wait
    ' response processor should close the socket with disconnect
    ' there could be a timeout so we have a forced close.
    ' TODO: CCheck for a port that gets stuck in a closing state
    'if(closeWaitState > 0)
      'id := DecodeId(closeWaitState)
      'if(id > -1)
        'Socket.Close(id & tcpMask)
    'pause(100)
return
DAT
  approot               byte    "\", 0
  defaultpage           byte    "index.htm", 0
  logfile               byte    "log.txt", 0
  'binFile               byte    "filename.bin", 0
  FS                    byte    "/", 0
  fn                    byte    "filename=", 0
  doublequote           byte    $22, 0
  crlf                  byte    13, 10, 0
  crlf_crlf             byte    13, 10, 13, 10, 0
  uploadfile            byte    $0[12], 0
  uploadfolder          byte    "uploads", 0
  tempNum               byte    "0000",0
  multipart             byte    "Content-Type: multipart/form-data; boundary=",0
  boundary              byte    $2D, $2D
  boundary1             byte    $0[64]
  'loadme                file    "TogglePin0.binary"
&#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
&#9474;                                                   TERMS OF USE: MIT License                                                  &#9474;
&#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
&#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation    &#9474;
&#9474;files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,    &#9474;
&#9474;modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software&#9474;
&#9474;is furnished to do so, subject to the following conditions:        &#9474;
&#9474;        &#9474;
&#9474;The above copyright notice and this permission notice shall be included in all copies or substantial ions of the Software.&#9474;
&#9474;        &#9474;
&#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE          &#9474;
&#9474;WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR         &#9474;
&#9474;COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,   &#9474;
&#9474;ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                         &#9474;
&#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
And here is the link to my Spinnerete if you want to try a connection and tell me what result you http://24.230.203.105:5555/index.htm
  • Mike GMike G Posts: 2,702
    edited 2012-07-23 20:30
    Try lengthening the retry delay.
    See the following post (18) for more information.
    http://forums.parallax.com/showthread.php?138781-Spinneret-Errors-%28Can-t-load-page!%29
  • twctwc Posts: 107
    edited 2012-07-24 06:18
    Using Explorer I can access your server, but the LED: state isn't shown (it's always blank) so I don't know if the LED_ON, LED_OFF control is working.
  • PodionPodion Posts: 90
    edited 2012-07-24 10:55
    Ok thank you TWC ! I will check for the led status.
    edited 2012-07-25 18:43
    I fix The LED State. And for my IPhone I just change those
    DELAY           = $10
      MAX_TRIES       = $25
    Now all work. But I want to know if it's possible to the LED to not turning off wen i click on the LED.htm link ? And if it is possible to show the current LED status even wen it's the firs time I load the LED.htm ?
    My problem is that i don't want necessarily to change the LED or light status wen I'm out of my house .. i just want to know the status. If someone turn on the light i don't want to make I'm freak because the light is turning off all time i check the LED status..
    edited 2012-07-25 18:56
    See the Service and Ajax section of the tutorial.
    http://spinneret.servebeer.com:5000/services/ajaxled.htm
    A simple AJAX HTTP GET request can return the state of any pin and update the DOM.
    This is an example from the tutorial where the current time is requested when the page loads. Successive requests (Clicking the link) invoke an AJAX request where only the <span id="placeholder"></span> is updated in the DOM.
    <html>
    <head>
    <title>Get Time</title>
    <script language="javascript" type="application/javascript">
    //Gets the browser specific XmlHttpRequest Object
     function getXmlHttpRequestObject() {
    	 if (window.XMLHttpRequest) {
    		 return new XMLHttpRequest();
    	 } else if (window.ActiveXObject) {
    		 return new ActiveXObject("Microsoft.XMLHTTP");
    	 } else {
    		 alert("Your Browser does not support AJAX!\nIt's about time to upgrade don't you think?");
     //XmlHttpRequest object
     var req = getXmlHttpRequestObject();
     var htmlTarget;
     function getRequest(resource, elementId) {
    	// handle the case where a querystring is not detected
    	var char = "&";
     	if(resource.indexOf("?", 0) == -1) {
    		char = "?";
    	 if (req.readyState == 4 || req.readyState == 0) {
    		 req.open("GET", resource + char + 'ms=' + new Date().getTime(), true);
    		 req.onreadystatechange = handleResponse;
    		 htmlTarget = elementId;
    		 req.send(null);
    		 return false;
    function handleResponse() {
    	 if (req.readyState == 4) {
    		parseState(req.responseXML);
    function parseState(xDoc) {
    	var target = document.getElementById(htmlTarget);
    	target.innerHTML = xDoc.getElementsByTagName("time")[0].childNodes[0].nodeValue;
    </script>
    </head>
    <body style="background-color:beige;">
    <div style="width:600px;margin:auto;background-color:white;padding:10px;">
      <h1 style="text-align:center;color:blue;">Get Time</h1>
      <p>
        <a href="time.htm" onClick="return getRequest('xmltime', 'placeholder');">Get Time</a>
      </p>
      <p><span id="placeholder"></span></p>
    </div>
        <script language='javascript' type='text/javascript'>
        </script>
    </body>
    </html>
    Tutorial source files can be found on the Google Code repository
    http://code.google.com/p/spinneret-web-server/source/browse/#svn%2Ftrunk%2FMultiSocketServer_MikeG%2FTutorialSourceArchives%2Fhtml
    edited 2012-08-15 10:00
    Hello Mike,
    I tried to find a solution to my problem but I found nothing.
    The first time the page load status of the LED is alway "State." All I want is that when the page load status of the LED is "on" or "off".
    What can I modify in the code to avoid every time I refreshed the page the status LED always returns a "State"?
    <html><head>
    <title>J&A LUX Control</title>
         } else {
     var htmlTarget;
        var char = "&";
            char = "?";
             req.send(null);
             return false;
             var str = req.responseText;
             //alert(str);
             var placeholder = document.getElementById(htmlTarget);
             placeholder.innerHTML = str;
    </script>
    </head>
      <h1 style="text-align:center;color:blue;">LED</h1>
      <div style="text-align:center;"><a href="index.htm">Home</a> | <a href="led.htm">LUX Control</a></div>
    <h2>Section</h2>
      <p>
          <a href="led.htm" onClick="return getRequest('aled.htm?led=on', 'placeholder');">LED On </a> ::
          <a href="led.htm" onClick="return getRequest('aled.htm?led=off', 'placeholder');">LED Off</a>
      </p>
      <p>LED: <span id="placeholder">State</span></p>
    </div>
    </body>
    </html>
    {{&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;
    About:
    Usage:
      Required objects:
            • Request.spin
            • Response.spin
    Change Log:
    CON
      DELAY           = $10
      MAX_TRIES       = $25
      #0, DONE, PUT, CD
    DAT
      port                  word    5555
      remotePort            word    80
      uport                 word    5050
      emailPort             word    25
      debug                 byte    $0
      closedState           byte    00
      openState             byte    00
      listenState           byte    00
      udpListen             byte    00
      tcpMask               byte    11
      udpMask               byte    00
      debugSemId            byte    $00
      udpLen                long    $00
      globalCache           byte    $1
    VAR
      long StackSpace[20]
    OBJ
      Request       : "Request"
      debug := 1
      SDCard.Start
      pst.Start(115_200)
      pause(200)
      'Mount the SD card
      pause(200)
      pst.str(FillTime)
      if(Socket.Start)
        pst.char(13)
      else
        pst.dec(debugSemId)
        pst.char(13)
      SetMac(@mac)
      SetSubnet(@subnet)
      SetIP(@ip)
        Request.Release(id)
        pause(50)
      pst.char(13)
        Socket.Listen(id)
        pst.dec(id)
        pst.char(13)
        pause(50)
      pause(250)
      StackDump
      QueueDump
      Main
      ''HTTP Service
      repeat
          if(debug)
            pause(DELAY)
          else
            pause(DELAY)
          id := DequeueSocket
          if(id < 0)
            next
          if(debug)
            pst.dec(id)
            pst.char(13)
          reset := false
              waitcnt((clkfreq/300 ) + cnt)
              if(packetSize > 12)
                quit
              if(i == MAX_TRIES)
                Request.Release(id)
                reset := true
                if(debug)
                  StackDump
                  pst.char(13)
                  QueueDump
          if(reset)
            next
          if(debug)
            pst.char(13)
            HeaderLine1(id)
          else
            pause(DELAY)
          ' Process router
          Dispatcher(id)
          Request.Release(id)
          debugCounter++
      GotoMain
    PRI SendLedResposne(id) | headerLen, qstr
            '' Exit if there is no querystring
            if(qstr == 0)
                    return
            '' Turn the LED on if the led= value is "on"
            if (strcomp(string("on"), qstr ))
                    LedStatus(1)
            else
                    LedStatus(0)
       '' Build and send the header
            '' Send the value of led= on or off
            Socket.txTCP(id, qstr, strsize(qstr))
            return
    PRI GotoMain
      Main
    PRI Dispatcher(id)
      if(strcomp(Request.GetFileName(id), string("aled.htm")) AND Request.GetDepth(id) == 1)
            SendLedResposne(id)
                    return
      return
            return
      dira[24]~~
      outa[24] := state
      return
      pst.char(13)
        'send 404 error
        WriteError(id)
        return
        'send 404 error
        WriteError(id)
        return
      else
        repeat
            quit
          ' Bailout
          if(i++ > 1_000_000)
            WriteError(id)
            quit
      SDCard.closeFile
      return
      '' Simple 404 error
      return
            return false
      return true
          return true
      return false
      ptr := @udpdata
      FillHttpDate
      ptr += 3
      ptr += 3
      return
      ptr := @time
      rtc.readTime
      ptr += 3
      ptr += 3
      ptr += 5
      ptr += 3
      ptr += 3
      return @time
      ptr := @httpDate
      rtc.readTime
      ptr += 3
      ptr += 5
      ptr += 3
      ptr += 3
      return @httpDate
      offset := 0
      if(number < 10)
        offset := 1
    '' SDCard Logger
      else
      SDCard.closeFile
    '' Socekt helpers
      return id & tcpMask
        if(01 & value)
          return 0
        if(10 & value)
          return 1
        if(00 & value)
          return 2
        if(00 & value)
          return 3
      return -1
        return false
      tmp := |< id
      'Unique check
        return false
      fifoSocket |= tmp
      return true
      repeat 4
          return false
        encodedId <<= 8
      return true
        return -2
      fifoSocket >>= 8
      fifoSocketDepth--
      lockclr(debugSemId)
    PRI ResetSocket(id)
      Socket.Close(id)
      tmp := |< id
      tcpMask &= tmp
      tmp := |< id
      if(state == 1)
        tcpMask |= tmp
      else
        tmp := !tmp
        tcpMask &= tmp
      return
      return
      return
      return
      return
      return
      return
      return
      return
      return
    PRI QueueDump
      clsd := closedState
      open := openState
      lstn := listenState
      ulst := udpListen
      lockclr(debugSemId)
      pst.char(13)
        pst.dec(id)
        pause(1)
      pst.bin(clsd, 4)
      pst.bin(open, 4)
      pst.bin(lstn, 4)
      pst.bin(estb, 4)
      pst.bin(clwt, 4)
      pst.bin(clng, 4)
      pst.bin(ulst, 4)
      pst.char(13)
      pst.char($20)
      i := 0
        pst.char($2F)
    PRI Pause(Duration)
      return
      repeat
          case(status[id])
            if(tmp > -1)
              QueueSocket(tmp)
              tmp := |< tmp
              tmp := !tmp
              value &= tmp
        lockclr(debugSemId)
        if(closedState > 0)
          if(id > -1)
        if(openState > 0)
          if(id > -1)
          'if(id > -1)
        'pause(100)
    return
    DAT
      approot               byte    "\", 0
      FS                    byte    "/", 0
      crlf                  byte    13, 10, 0
    edited 2012-08-16 12:50
    Podion,
    Use an AJAX GET to retrieve the pin state after the page has loaded. You will update two files, HttpServer and aled.htm.
    1) Update the SendLedResposne method to make an additional querystring check. We're looking for ?led=what. If we see a "what" then get the pin state INA[23]. If the pin state is 1, send the string "on" otherwise send "off".
      if(qstr == 0)
        return false
        LedStatus(1)
      if (strcomp(string("off"), qstr ))
        LedStatus(0)
      if (strcomp(string("what"), qstr ))
        if(ina[23])
          qstr := string("on")
        else
          qstr := string("off")
      return true
    2) Update aled.htm by adding an AJAX call below the "State" text.
    <html><head>
         } else {
     var htmlTarget;
        var char = "&";
            char = "?";
             req.send(null);
             return false;
             //alert(str);
    </script>
    </head>
      <div style="text-align:center;"><a href="index.htm">Home</a> | <a href="aled.htm">LUX Control</a></div>
    <h2>Section</h2>
      <p>
          <a href="#" onClick="return getRequest('aled.htm?led=on', 'placeholder');">LED On </a> ::
          <a href="#" onClick="return getRequest('aled.htm?led=off', 'placeholder');">LED Off</a>
      </p>
      <script language="javascript" type="text/javascript">
      	getRequest('aled.htm?led=what', 'placeholder')
      </script>
    </div>
    </body>
    </html>
    When the page loads, You'll see "State" while the AJAX GET retrieves the pin state from the server. But it will change.
    Can we make this thread as solved?
    edited 2012-08-19 21:48
    Almost .. When I use the following code, the LED stay "on" when I refreshed the page but the "LED : State" always return to "State".
    About:
    Usage:
      Required objects:
            &#8226; Parallax Serial Terminal.spin
            &#8226; W5100_Indirect_Driver.spin
            &#8226; S35390A_SD-MMC_FATEngineWrapper.spin
            &#8226; Request.spin
            &#8226; Response.spin
            &#8226; StringMethods.spin
            &#8226; S35390A_RTCEngine.spin
    Change Log:
    CON
      DELAY           = $10
      MAX_TRIES       = $25
      #0, DONE, PUT, CD
    DAT
      port                  word    5555
      remotePort            word    80
      uport                 word    5050
      emailPort             word    25
      debug                 byte    $0
      closedState           byte    00
      openState             byte    00
      listenState           byte    00
      udpListen             byte    00
      tcpMask               byte    11
      udpMask               byte    00
      debugSemId            byte    $00
      udpLen                long    $00
      globalCache           byte    $1
    VAR
      long StackSpace[20]
    OBJ
      Request       : "Request"
      debug := 1
      SDCard.Start
      pst.Start(115_200)
      pause(200)
      'Mount the SD card
      pause(200)
      pst.str(FillTime)
      if(Socket.Start)
        pst.char(13)
      else
        pst.dec(debugSemId)
        pst.char(13)
      SetMac(@mac)
      SetSubnet(@subnet)
      SetIP(@ip)
        Request.Release(id)
        pause(50)
      pst.char(13)
        Socket.Listen(id)
        pst.dec(id)
        pst.char(13)
        pause(50)
      pause(250)
      StackDump
      QueueDump
      Main
      ''HTTP Service
      repeat
          if(debug)
            pause(DELAY)
          else
            pause(DELAY)
          id := DequeueSocket
          if(id < 0)
            next
          if(debug)
            pst.dec(id)
            pst.char(13)
          reset := false
              if(packetSize > 12)
                quit
              if(i == MAX_TRIES)
                Request.Release(id)
                reset := true
                if(debug)
                  StackDump
                  pst.char(13)
                  QueueDump
          if(reset)
            next
          if(debug)
            pst.char(13)
            HeaderLine1(id)
          else
            pause(DELAY)
          ' Process router
          Dispatcher(id)
          Request.Release(id)
          debugCounter++
      GotoMain
            if(qstr == 0)
                    return false
              LedStatus(1)
            else
              LedStatus(0)
            return true
    PRI GotoMain
      Main
    PRI Dispatcher(id)
            SendLedResposne(id)
                    return
      return
    PRI Led(id) | qstr
        LedStatus(1)
      return
      dira[24]~~
      outa[24] := state
      return
      pst.char(13)
        'send 404 error
        WriteError(id)
        return
        'send 404 error
        WriteError(id)
        return
      else
        repeat
            quit
          ' Bailout
          if(i++ > 1_000_000)
            WriteError(id)
            quit
      SDCard.closeFile
      return
      '' Simple 404 error
      return
            return false
      return true
          return true
      return false
      ptr := @udpdata
      FillHttpDate
      ptr += 3
      ptr += 3
      return
      ptr := @time
      rtc.readTime
      ptr += 3
      ptr += 3
      ptr += 5
      ptr += 3
      ptr += 3
      return @time
      ptr := @httpDate
      rtc.readTime
      ptr += 3
      ptr += 5
      ptr += 3
      ptr += 3
      return @httpDate
      offset := 0
      if(number < 10)
        offset := 1
    '' SDCard Logger
      else
      SDCard.closeFile
    '' Socekt helpers
      return id & tcpMask
        if(01 & value)
          return 0
        if(10 & value)
          return 1
        if(00 & value)
          return 2
        if(00 & value)
          return 3
      return -1
        return false
      tmp := |< id
      'Unique check
        return false
      fifoSocket |= tmp
      return true
      repeat 4
          return false
        encodedId <<= 8
      return true
        return -2
      fifoSocket >>= 8
      fifoSocketDepth--
      lockclr(debugSemId)
    PRI ResetSocket(id)
      Socket.Close(id)
      tmp := |< id
      tcpMask &= tmp
      tmp := |< id
      if(state == 1)
        tcpMask |= tmp
      else
        tmp := !tmp
        tcpMask &= tmp
      return
      return
      return
      return
      return
      return
      return
      return
      return
      return
    PRI QueueDump
      clsd := closedState
      open := openState
      lstn := listenState
      ulst := udpListen
      lockclr(debugSemId)
      pst.char(13)
        pst.dec(id)
        pause(1)
      pst.bin(clsd, 4)
      pst.bin(open, 4)
      pst.bin(lstn, 4)
      pst.bin(estb, 4)
      pst.bin(clwt, 4)
      pst.bin(clng, 4)
      pst.bin(ulst, 4)
      pst.char(13)
      pst.char($20)
      i := 0
        pst.char($2F)
    PRI Pause(Duration)
      return
      repeat
          case(status[id])
            if(tmp > -1)
              QueueSocket(tmp)
              tmp := |< tmp
              tmp := !tmp
              value &= tmp
        lockclr(debugSemId)
        if(closedState > 0)
          if(id > -1)
        if(openState > 0)
          if(id > -1)
          'if(id > -1)
        'pause(100)
    return
    DAT
      approot               byte    "\", 0
      FS                    byte    "/", 0
      crlf                  byte    13, 10, 0
    <html>
    <head>
         } else {
     var htmlTarget;
        var char = "&";
            char = "?";
             req.send(null);
             return false;
             //alert(str);
    </script>
    </head>
    <h2>Section</h2>
      <p>
      </p>
      </script>
    </div>
    </body>
    </html>
    Wen i use the new code you just send me the "State" of the Led is always update on the webpage. But all time I reload the page the state of the Led return to "off" and the Led is close.
    About:
    Usage:
      Required objects:
    Change Log:
    CON
      DELAY           = $10
      MAX_TRIES       = $25
      #0, DONE, PUT, CD
    DAT
      port                  word    5555
      remotePort            word    80
      uport                 word    5050
      emailPort             word    25
      debug                 byte    $0
      closedState           byte    00
      openState             byte    00
      listenState           byte    00
      udpListen             byte    00
      tcpMask               byte    11
      udpMask               byte    00
      debugSemId            byte    $00
      udpLen                long    $00
      globalCache           byte    $1
    VAR
      long StackSpace[20]
    OBJ
      Request       : "Request"
      debug := 1
      SDCard.Start
      pst.Start(115_200)
      pause(200)
      'Mount the SD card
      pause(200)
      pst.str(FillTime)
      if(Socket.Start)
        pst.char(13)
      else
        pst.dec(debugSemId)
        pst.char(13)
      SetMac(@mac)
      SetSubnet(@subnet)
      SetIP(@ip)
        Request.Release(id)
        pause(50)
      pst.char(13)
        Socket.Listen(id)
        pst.dec(id)
        pst.char(13)
        pause(50)
      pause(250)
      StackDump
      QueueDump
      Main
      ''HTTP Service
      repeat
          if(debug)
            pause(DELAY)
          else
            pause(DELAY)
          id := DequeueSocket
          if(id < 0)
            next
          if(debug)
            pst.dec(id)
            pst.char(13)
          reset := false
              if(packetSize > 12)
                quit
              if(i == MAX_TRIES)
                Request.Release(id)
                reset := true
                if(debug)
                  StackDump
                  pst.char(13)
                  QueueDump
          if(reset)
            next
          if(debug)
            pst.char(13)
            HeaderLine1(id)
          else
            pause(DELAY)
          ' Process router
          Dispatcher(id)
          Request.Release(id)
          debugCounter++
      GotoMain
            if(qstr == 0)
                    return false
              LedStatus(1)
            else
              LedStatus(0)
              if (ina[24])
              else
            return true
    PRI GotoMain
      Main
    PRI Dispatcher(id)
            SendLedResposne(id)
                    return
      return
      dira[24] ~~
      outa[24] := state
      return
      pst.char(13)
        'send 404 error
        WriteError(id)
        return
        'send 404 error
        WriteError(id)
        return
      else
        repeat
            quit
          ' Bailout
          if(i++ > 1_000_000)
            WriteError(id)
            quit
      SDCard.closeFile
      return
      '' Simple 404 error
      return
            return false
      return true
          return true
      return false
      ptr := @udpdata
      FillHttpDate
      ptr += 3
      ptr += 3
      return
      ptr := @time
      rtc.readTime
      ptr += 3
      ptr += 3
      ptr += 5
      ptr += 3
      ptr += 3
      return @time
      ptr := @httpDate
      rtc.readTime
      ptr += 3
      ptr += 5
      ptr += 3
      ptr += 3
      return @httpDate
      offset := 0
      if(number < 10)
        offset := 1
    '' SDCard Logger
      else
      SDCard.closeFile
    '' Socekt helpers
      return id & tcpMask
        if(01 & value)
          return 0
        if(10 & value)
          return 1
        if(00 & value)
          return 2
        if(00 & value)
          return 3
      return -1
        return false
      tmp := |< id
      'Unique check
        return false
      fifoSocket |= tmp
      return true
      repeat 4
          return false
        encodedId <<= 8
      return true
        return -2
      fifoSocket >>= 8
      fifoSocketDepth--
      lockclr(debugSemId)
    PRI ResetSocket(id)
      Socket.Close(id)
      tmp := |< id
      tcpMask &= tmp
      tmp := |< id
      if(state == 1)
        tcpMask |= tmp
      else
        tmp := !tmp
        tcpMask &= tmp
      return
      return
      return
      return
      return
      return
      return
      return
      return
      return
    PRI QueueDump
      clsd := closedState
      open := openState
      lstn := listenState
      ulst := udpListen
      lockclr(debugSemId)
      pst.char(13)
        pst.dec(id)
        pause(1)
      pst.bin(clsd, 4)
      pst.bin(open, 4)
      pst.bin(lstn, 4)
      pst.bin(estb, 4)
      pst.bin(clwt, 4)
      pst.bin(clng, 4)
      pst.bin(ulst, 4)
      pst.char(13)
      pst.char($20)
      i := 0
        pst.char($2F)
    PRI Pause(Duration)
      return
      repeat
          case(status[id])
            if(tmp > -1)
              QueueSocket(tmp)
              tmp := |< tmp
              tmp := !tmp
              value &= tmp
        lockclr(debugSemId)
        if(closedState > 0)
          if(id > -1)
        if(openState > 0)
          if(id > -1)
          'if(id > -1)
        'pause(100)
    return
    DAT
      approot               byte    "\", 0
      FS                    byte    "/", 0
      crlf                  byte    13, 10, 0
    <html><head>
         } else {
     var htmlTarget;
        var char = "&";
            char = "?";
             req.send(null);
             return false;
             //alert(str);
    </script>
    </head>
    <h2>Section</h2>
      <p>
      </p>
     [LEFT][FONT=Parallax]<script language="javascript" type="text/javascript">
           getRequest('aled.htm?led=what', 'placeholder') [/FONT][/LEFT]
    </div>
    </body>
    </html>
    Is it possible to have the "LED: State" always update on the page and the Led status remain the same even if I reload the page ?
    If you want to see the page http://24.230.203.105:5555/index.htm it is your last code that I use now.
    Thank you !!
    edited 2012-08-20 08:30
    The SendLedResponse method in your last post is not the updated method. Please take a closer look at the the the first IF blocks. As written in your last post, if the query string is NOT led=on then the LED is turned off. You must update the if block to filter for both "on" and "off".
    Also please see the updated Dispatcher method.
    Updated methods
      if(qstr == 0)
        return false
        LedStatus(1)
        LedStatus(0)
        if(ina[23])
        else
      return true
    PRI Dispatcher(id)
        if(SendLedResposne(id))
          return
      return
    You are right it is my mistake. With this code everything works! Thank you very much Mike! You're awesome! :smile:
