PIR Motion Sensor
Hi.
My name is metrik and i am new to motion sensors but i would reall like to add it to a project i am working on. and i want to use the motion sensor to turn on the power to my project. any one with some help on where to start and any other kind of help would be great.
Thanks every one!
Thanks every one!
Next time you post a question like this one, it really helps to be specific about what you want to do. When you say "turn on the power", what sort of voltage and current are you talking about? Do you want the power turned on when the PIR sensor detects motion? Do you want the power to stay on? For how long? How does the power get turned off?
i made a Arduino on a breadboard and then but it in a case with a cooling fan. and i am try to make the Arduino turn on and run the program that it has been programmed to run. and as for turning it off i have a switch that i have installed on it already that i would like to use
and i also have a card reader that i would like to try and add to my project to so that if you dont have the right card you cant trun it all the way on.
Thank for the reply Mike!
