ColorPAL Troubles
G'day,
I'm desperatly getting ready for a robotics comp and I've been (continually) having trouble with the ColorPAL sensors. Mainly the just stop working, with no aparent reason, I will try and get more details up ASAP (Code, etc), like within the next 10 minutes, but I thought maybe it was a well-known-problem-that-I-don't-know-about... yet...
All help accepted gratfully!
-John
P.S. By memory, I'm using this ColorPAL Driver: http://obex.parallax.com/objects/629/
-John
The wiring of the sensor is as per normal, with a 3-pin header extension wire.
Sig, VDD, GNDJaws.zip
For example:
1. I set the robot up on the course
2. I switch on the motors
3. The robot does what it normally does
4. At some unknown time in the course the sensors stop 'scanning colors' and freeze on any perticular color (Any one).
I'll keep you informed!
-John
John
In the ColorPAL object. Change the baudrate to 7200.
