Can the PINK Netburner Kit be accessed over the internet?
A while back I saw that the Parallax Internet Netburner Kit was going to be discontinued. So I decided to go ahead and buy one before it was out of stock. When I received it, i was busy working on other projects so I never really got the chance to mess with it other than to make sure it would work on my home network. well now I finally have time to mess with this thing and I am not quite sure on how to access it from and outside network or if it is even possible.
I'v got it working on my Home network, so anything connect to my wifi can access it with the"http://xxx.xxx.xxx.xxx/nb_factory.htm" address.(x's being the ip)
My question is, what needs to be done to access this from anywhere?
Thanks!
Thanks!
Would the address I type in at a remote location be the same as the address i type in on the same network " 192.168.1.113/index.htm"?
Log in to No-IP.com. On the Main Page, Click on Add A Host. Once you create a Host and save go to Manage Hosts. Select Host you want to manage, then Modify. Your IP address should come up and you can choose Web Redirect. If IP address is not there type in the one that comes up on your No-IP on PC. Enter the port you want to forward to and selcet update at bottom of screen.
If you are still having issues contact tech support. They are very helpful and can get you up and running fairly quick.
If you want to test from outside I would be happy to do that for you. Just send over the ip info. (I am a PC Technician and I do not hack other peoples systems.)
Since he is on a Dynamic IP it will not work constantly until he gets a Static IP. His LAN side is working. It is the WAN side where he is having issues.
Well, that is not quite the same thing as "it will not work until he gets a Static IP".
Wait if i change the port to 80 , still put 68?
Also, thanks for all the help. i tried many different things yesterday with some success(by some success i mean i got it to work once). but I'm going back at it again today. ill keep you all updated
Lots of excellent advice in this thread, especially Mike's port forwarding description. I would like to add just a few comments that might be helpful.
With regard to a changing IP, some routers also support dynamic DNS so you could access your device by name instead of IP address, and the name will get updated by the router sending a UDP packet to the dynamic DNS server any time your router's IP address changes. I am not sure how NO-IP works, but it might be similar.
Some ISPs block port 80 and 8080, so if those do not work try a different port number. Ports below 1024 are reserved "well known" port numbers, so usually something higher works.
Lastly, the NetBurner PINK is alive and well, we sell it directly now. We also have a PINK-LC, which is a lower cost unit, but it is 3.3V only and cannot be used with 5V devices. We have customers using it with the Propeller and it works very well. Here is a link if anyone is interested: http://www.netburner.com/pink/
Best regards,
Tom
