how to integrate the angle rate of gyroscope L3G4200D
The demo code can only get the angle rate, but I want to integrate the value to get angle. How can I integrate the discrete values? And I also have the same problem to get position information from acceleration. Anyone can help me? Thanks. (I use BS2)
1. You must have a constant delta-t (sample time) in order to get a reliable answer
2. You'll have to scale your answer if you want it in terms of real units
And, most importantly:
3. You will not get valid results with this method for any sample period longer than a few seconds. The sensors (gyros and accelerometers) are just too noisy. Do a search for IMU and Kalman filtering to see why.
And now, a slight modification: if you're very careful, you might get decent results with the accelerometer for short paths (20 feet or so). There was a forum post about it a while back, possibly even in this search:
