Eddie Wheel Connection Issue
I've got a new Eddie and have some issues.
First, why is there no detailed instructions on how to connect the Wheel controllers? Neither the manual nor the assembly video shows how to connect the cables.
There are three possibilities on each controller, which ones do I connect??!
The only reference in the assembly manual is:
"Connect the three-pin cable from the right Position Controller to Pin-set 11 in the Encoders section of
the Control Board. The black wire should be on the outer-most pin of the three-pin header."
What is the "Encoders" sections? Sorry, but I don't get how the wheels are connected.
I tried to guess, but the Robot Dashboard will not run with an error, so I assume I did it wrong.
Also having issues with RDS4 as I installed Kinect SDK 1.5 - I guess RDS4 does not support that. I had to uninstall and install 1.0. Would have been nice to know, but maybe that's a MS issue.
Hopefully I'm not the only one with this issue.
Edit: Found this post http://forums.parallax.com/showthread.php?137253-Eddie-Encoder-issue I'll try checking my settings.
Welcome to the Forums!
How's it coming? Do you still need help?
-MattG
yes I do in fact. I accidently posted in the general forum, probably should have posted here, but I don't have a way to move my post.
http://forums.parallax.com/showthread.php?141281-Error-receiving-reading-speed-values-from-FW
JJ
Did you take a look at the product doc here? Specifically pages 8-10. I don't think we have a "hello world" sample for this controller, but I could be wrong. We are just about to release a new encoder (waiting for documentation to finish it up). It's a much simpler type of quadrature encoder that will certainly have a "hello world" sample soon.
I'll post it here as soon as it's finished.
-MattG
http://www.generationrobots.com/encodeurs-eddie,us,8,80.cfm
Todd
I'm currently struggling with getting VPL to connect to the hardware (works in simulator, but fails to connect). I think that I read that there was a code modification for the manifest, but eager for any tips.
Try the generic manifest using VPL and see if it works. I also have a couple of examples on my blog that have manifests included (roboticsathome.wordpress.com). that may help you.
Todd
