Milone eTape problems
I was wondering if anybody knows how to set up the Mionetech eTape sensor using the BS2 board. I am not getting any output from the sensor. I used the circuit titled simple and the source code attached. When I connected the circuit to an ohmmeter, It gave me the proper output, yet I can't seem to get the sensor to output using RCTime. Also the appnotes detail how to use the solder tab version. How would you hook up the 4 prong version detailed in the datasheet.
bmp
58K
