10Mhz xtal _clkmode question — Parallax Forums
BitsBits Posts: 414
edited 2012-07-13 16:49 in Propeller 1
Is this right? I am using a 10Mhz xtal.
CON
  _clkmode        = xtal1 + pll8x
  _xinfreq        = 10_000_000
  • hover1hover1 Posts: 1,929
    edited 2012-07-12 09:23
    Bits wrote: »
    CON
    Yes,
    That is correct for 80Mhz operation.
    Jim
  • pik33pik33 Posts: 2,417
    edited 2012-07-12 09:27
    I think yes, this is right.
    I use this combination of constants:
    _clkmode=xtal1+pll8x
    _clkfreq = 80_000_000
    edited 2012-07-12 09:30
    Bits, yes, your configuration is correct.
  • BitsBits Posts: 414
    edited 2012-07-12 09:44
    Thank you.
    I am getting strange behavior when using full duplex object. From past projects this seemed to point to the wrong xtal settings being used.
    Ill keep looking into it. Thanks again.
  • shimniokshimniok Posts: 177
    edited 2012-07-13 07:24
    Just a thought... perhaps there's a bit of error in the bit rate due to different clock speed?
    http://www.wormfood.net/avrbaudcalc.php/
    edited 2012-07-13 14:06
    shimniok wrote: »
    There should not be. Once I set the speed in the object the overall system speed should remain 80Mhz.
    In fact I found the problem, bad solder joint on xtal.
  • cavelambcavelamb Posts: 724
    So it's running correctly now?
