Output Voltage
I've attached two separate variable DC power supplies to the stamp as part of a double switch circuit with 2 transistors and 2 relays. Each relay/transistor set needs to be separate and associated with the high voltage and low voltage from the two power supplies. I need to know if there's a way to bypass the 5V regulator. I'm getting multimeter readings that have 5 volts added to what I set on the power supply, but one of them is coming out negative and I don't think the circuit is set up correctly. How can I connect my power supplies to get readings that are not adjusted by 5V?
With this setup (which I copied from a previous researcher and fully understand does not make sense--especially connecting Vin to the grounds for each power source) I wrote a BASIC program to turn on the high voltage then off. Then Low voltage on and off. The high voltage is positive and reads on the multimeter as 5V above what the power source is set to. The low voltage is read as negative on the multimeter, but is also 5V higher than on the source.
I would like to get an output voltage of about 2.5V from the low voltage and 6-7V from the high voltage, so although my external power sources CAN put 5V in, that isn't the output I want.
Can you retry posting the whole schematic? You provided only 50% and there is no clear way to see where the voltages might double.
Also, if you are drawing the schematic from memory, please verify it is what you built as there may be actual wiring errors involved that we cannot recognize.
See Nuts and Volts Column #6 for a discussion of how to control relays using a Stamp. Go to Parallax's main webpage and click on the Resources tab. You'll see a link to the Nuts and Volts Columns index and find #6.
You may need to start all over from scratch. What is this for? What is it supposed to do?
The starting from scratch idea is sounding tempting. I am still a little confused why you keep mentioning the +5V and -5V from the power sources. I am not setting my external power supplies to this voltage. I'm setting them to my desired low and high voltage outputs of 2.5V and 7V respectively. Am I not supposed to do this? If so, how can I get my desired output voltage if I'm only dealing in +5V and -5V?
The 'internal diagrams' of your relays seem to be very much in error. I can understand that the relays are intended to be Double Pole Double Pole relays that are being used as a simple Single Pole Double Throw switches, but it seems that you have connects where none should be.
As it is, it seems one relay is being powered at 2.5volts and the other at 6.5 volts -- not a good idea. Relays need a correct voltage and adequate amps to properly engage. Standard relay coils are 5, 6, 9, 12, and 24 volts DC or 120 and 240 VAC.
One relay might be enough to switch between High and Low voltage, so why two? You want the relays to provide an off condition as well. Maybe a redesign of one relay to handle the Power ON/OFF and the other to handle the HIGH/LOW as a single output would make your life simpler.
It seems as if you have the High voltage and the Low voltage going to the coils (at 7 and 8) and the relay switches. But Grounding the switches in an off condition is not necessary and may be unwise if power is available. This may cause a short circuit condition.
The relay coils might be adapted to be powered by 6.5 volts and controlled via the transistors going to the Basic Stamp. But are you going to have to reduce the voltage to drive the coils at some other specified voltage (6 Volts or 5 volts are usual - read the relay lables). 12 and 24 volt relays need a voltage near those levels.
Are you using one power supply with 2.5 v and another with 6.5 v and a common ground to get 6.5 V in HIGH and 2.5 volts in LOW? What is powering the BasicStamp and at what voltage?
http://en.wikipedia.org/wiki/Relay
Your transistor diagrams offer no information as to whether they are PNP or NPN or where the Collector, Base, and Emitter are connected. Leaves much to the imagination. Polarity may be all wrong. What are the transistors 2n3904 or 2n2222 or ????
Where are you going to get 5 volts regulated for the BasicStamp from if you by-pass the BasicStamp's regulation?
Only half of the multimeter circuit is shown. The dashed line makes no sense in the way it is used. Do you really want to seperate outputs to provide 2.5v to one location and 6.5v to another; or could just one output shifting from High to Low be appropriate?
If you are using an adjustable dual bench power supply, life is easier --- BUT you may have to drive the relays at some other proper voltage. Where you get that other voltage from needs consideration. The relay coils are isolated from the switches and can have a independent power source controlled by the BasicStamp.
A complete redesign would make your life much easier than relying on something nobody understood after the other person left.
You might consider to re-program the Basic Stamp for one pin to toggle High and Low and another pin to toggle on and off. That would be more conservative and logical than having one pin High and the other pin Low as you can get a simultaneous 'on' condition if both pins go High due to a code error. Or do you really require a simultaneous condition on two separate outputs?
Before you get to far into this.....
Test the High/Low circuit without the BasicStamp - just provide 5 volts to the transistor base. Do the same with the On/Off
@Mike
A clear explanation of all the available power supplies from Claire_Drexel would help all of us.
The bad readings on the multimeters with 5 volt offsets is likely due to having the transistors wired improperly. She is lucky if there is no real damage as a negative voltage to the BasicStamp output pins would be fatal.
Since one relay or both relays would be off, the two outputs can be connected together and drive for motion.
The only thing I would change is the 10K resistor between the BasicStamp output and the transistor, that is way too high. Some would say 240ohms, but I would use about 1000ohms and 2n2222 transistor with a 5 or 6 volt relay. Actually any value between 240 and 1000ohms would likely work well, below 240 might damage the BasicStamp I/O
