Quick Question
Android
Can Ping))) sensor be controlled by outh and dirh? Because I connected a 7 segment LED digit display to my boe-bot with Ping))) sensor and servo and it started acting up
- Android
- Android
thank you Mike
-Android
None of this will work if you're trying to use I/O pin 15 for one of the LED pins. In that case, you'll have to move the PING to one of the I/O pins in the range 0-7 or move the LED to I/O pins 0-7 and leave the PING connected to I/O pin 15.
-Android
