Trouble making multiple measurements with PING
I'm making three measurements in quick succession with the PING so I can toss out the high and low values to cut down on spurious readings. Regardless of the delay I use between the subsequent readings (from 250 us to 1.5 ms), however, the second and third readings bounce around a lot (by an order of magnitude); the first reading tends to be pretty accurate. Any idea why the subsequent readings are so variable? By delay I mean the time from when the echo return pulse goes low until I send a new trigger pulse. Thanks.
