Is there a way to increase the font size for the built-in Simple Terminal? Also, I notice the version of Side I'm using (0.7.2) has two commands to increase the font size on the 'Tools' menu, not sure if it was an oversight or ? (Could use one for the edit window, one for the Terminal). Also, is there a way to adjust the Simple Terminal CRLF behavior? - using '\r' my app displays ok on PST (with linefeed (0x0a) and new line (0x0d) enabled in PST 'Prefs') but not linefeeding with Simple Term (i.e. each line overwrites the previous one). Not a biggie, I could switch to '\n'. All for keeping it simple, but maybe a few basic options (ex: font, CR/NL, local echo) would go a long way. As an aside I've often wished Terminals had a 'hex mode' i.e.
123<crlf>
...would display as...
<31><32><33><0D><0A>
...helpful for debugging, can switch between ASCII and binary interpretation without changing program.
I've had good luck using spin2cpp, Side and PropGCC on a non-trivial (500 line) program - fine work indeed gentleman!
Font type/size, background/foreground color, PST features, and LF/CR adaptation have been specified.
Hex mode is not a specified feature, but could be added if time allows.
Two commands CTRL+'=' and CTRL+SHIFT+'=' to increase SimpleIDE editor font size was intentional - which one should be removed?
123<crlf>
If you must get rid of one, get rid of CTRL+SHIFT+'=', since its complement doesn't work for reduction. In any event, so long as CTRL+'+' and CTRL+'-' on the keypad work, I think that's what most people will use, unless they're working on a laptop.
BTW, I like it better than the CTRL-arrow keys, the iconoclasm used in the Propeller Tool.
Since SHIFT+'=' is simply '+' which is a pretty standard 'increase text size' I say keep that.
By the way on the Mac substitute the COMMAND (or Apple) key for CTRL. On my iMac (Lion 10.7.4) SimpleIDE responds to COMMAND+'+' and COMMAND+'-' to increase and decrease text size.
Hmm, good point. So I guess CTRL+ and CTRL-, and if you have to hold down the shift key to get there, add SHFT to that formula. Whatever the keyboard, though, the numeric keypad is still the quickest, most consistent way to nirvana.
Oversights, boo-boos, and senior moments are just part of history, bud. Heaven knows, I've had my share.
But if you send Browser some shrimp, he might consider intervening on your behalf.
123<crlf>
--Steve
Anyway can we just use the same text zoom as web browsers?
Page Viewing Shortcuts
Full Screen (toggle)
F11
F11 (may depend on window manager)
Zoom Text Smaller
Ctrl+- (minus sign)
Cmd+- (minus sign)
Ctrl+- (minus sign)
Zoom Text Larger
Ctrl+= (plus sign)
Cmd+= (plus sign)
Ctrl+= (plus sign)
No Zoom (back to normal/100%)
Ctrl+0
Cmd+0
Ctrl+0
Well, Full Screen might be a bit much.
Edit: Seems the headings in this table did not cut and paste across. Sure you can see it's Windows, Mac, Linux keys.
Using CONTROL and the numeric keypad plus/minus should also work as it does in Firefox, Chrome etc.
