Mechanical Advantage And Force
To Those That May Be Interested
In another thread, I recently and briefly discussed a screw driven guillotine music wire cutter, and as mentioned in that thread, this was a third generation design. However it is noteworthy to mention that two of the designs were capable of cutting the wire, but the second design did not fulfill my vision of the machine as I could foresee it. During the construction of this cutter, as well as with other mechanical devices I have built, I had come to the conclusion that I needed more force than my motors could deliver. When building machinery or other items such as robots, there will be times when you just need more force than your motors, servos, or other power output devices can deliver. There are several ways to get more force out of a power output device, but it requires a gain of mechanical advantage.
During my adventures of machine building and other projects, I have used several means as a way of gaining a mechanical advantage or force, some of which are as follows:
Bruce
Wikipedia defines mechanical advantage as follows:
http://en.wikipedia.org/wiki/Mechanical_advantage
Mechanical advantage is a measure of the force amplification achieved by using a tool, mechanical device or machine system. Ideally, the device preserves the input power and simply trades off forces against movement to obtain a desired amplification in the output force. The model for this is the law of the lever.
- Levers
- Gears
- Wedges
- Screws
- Sprockets
- Pulleys
Bruce
The biggest lift I was involved in was 400 tons. At the time, it was the largest in North America. But these days, that is rather small.
Wedges end up being handy in the oddest of places. I have built a lot of temporary wood clamps that held work together while glue set with wedges rather than buy expensive clamps. And often, a wedge can open up a crack enough to insert a pry bar to lift something that seemed impossible to grasp.
Tripods of 2" water pipe can allow you to lift quite a bit with block and tackle.
I was going to quote Archimedes, but there is definitely some discrepancies in what he actually said between 287 and 212 B.C, so I will give you a couple of choices:
I suppose I will have to fire up the old Parallax powered time machine, just to find out what was actually said.Bruce
