Getting around the "Not a Long Address" problem when using DAT sections for byte code — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2012-07-03 23:05 in Propeller 1
I've got this problem when I use BST and the Spin tool is the same in that it insists upon references to addresses being aligned to long boundaries which makes sense when you are writing PASM code but not much if DAT sections are supposed to be more general-purpose.
In my byte code I have to calculate relative branches by hand at present because as soon as I perform a simple HERE - THERE calculation the compiler throws a fit if neither address is aligned on long boundaries.
Looking at the listing below you see how I have made it work by throwing in a long before PRTBYTE to make sure that it was aligned. Of course I could pad it manually as well but a long suffices to demonstrate that this keeps the compiler happy. The same also applies to the label DM1 at the end of the listing in that it needs to be aligned for the calculation DM1-PRTBYTE just previous to DM1, for this purpose I threw in a couple of NOPs. Without these the compiler throws up an error "Not a Long Address".
So does anyone have any ideas or perhaps there is another compiler out there that is a little more flexile? Of course I'd really love to be able to code macros just like we do in assembly but no such luck.
BTW, this little problem only affects the code that is "Spin" compiled as I then use the byte code VM to compile further definitions itself. But I want to make this a simple thing anyone can do in one or two simple steps.
EDIT: The calculation needs to be on it's address in hub RAM rather than assuming it's loaded into a cog. So the DM1-PRTHEX result is incorrect and can't be used like this.
0530(001B) 06          | _BOUNDS byte  OVER/2,PLUS/2,SWAP/2,EXIT/2
0531(001B) 0C          |
0532(001B) 08          |
0533(001B) 00          |
0534(001C)             | PRTHEX  ' ( n -- ) print n (0..$0F) as a hex character
0534(001C) 2D          |         byte  CLIT/2,$30,PLUS/2
0535(001C) 30          |
0536(001C) 0C          |
0537(001C) 05          |         byte  DUP/2,CLIT/2,$39,GT/2,_IF/2,3
0538(001D) 2D          |
0539(001D) 39          |
053A(001D) 20          |
053B(001D) 3E          |
053C(001E) 03          |
053D(001E) 2D          |         byte  CLIT/2,12,PLUS/2                      'Adjust for A..F
053E(001E) 0C          |
053F(001E) 0C          |
0540(001F) 49          | PRTCH   byte  EMIT/2,EXIT/2
0541(001F) 00          |
0544(0020) 00 00 00 00 |         LONG 0
0548(0021)             | PRTBYTE
0548(0021) 05          |         byte  DUP/2,CLIT/2,4,_SHR/2
0549(0021) 2D          |
054A(0021) 04          |
054B(0021) 1A          |
054C(0022) 3B          |         byte  RCALL/2,20 '-->PRTHEX                  'Due to limitations of Spin tool & BST this needs to be calculated by hand
054D(0022) 14          |
054E(0022) 3B          |         byte  RCALL/2,22
054F(0022) 16          |
0550(0023) 00          |         byte  EXIT/2
0551(0023)             | PRTWORD
0551(0023) 05          |         byte  DUP/2,CLIT/2,8,_SHR/2
0552(0023) 2D          |
0553(0023) 08          |
0554(0024) 1A          |
0555(0024) 3B          |         byte  RCALL/2,15,RCALL/2,17                 ' PRTBYTE
0556(0024) 0F          |
0557(0024) 3B          |
0558(0025) 11          |
0559(0025) 00          |         byte  EXIT/2
055A(0025)             | PRTSTR
055A(0025) 46          |         byte  RPOP/2
055B(0025) 05          | PSTLP   byte  DUP/2,CFETCH/2,DUP/2,_IF/2,3
055C(0026) 23          |
055D(0026) 05          |
055E(0026) 3E          |
055F(0026) 03          |
0560(0027) 49          |         byte  EMIT/2,_AGAIN/2,8
0561(0027) 41          |
0562(0027) 08          |
0563(0027) 03          |         byte  DROP/2,INC/2,PUSHR/2,EXIT/2
0564(0028) 0E          |
0565(0028) 45          |
0566(0028) 00          |
0567(0028)             | DEMO
0567(0028) 2E          | DUMP    byte  WLIT/2,00,$10
0568(0029) 00          |
0569(0029) 10          |
056A(0029) 12          |         byte  LIT0/2,DO/2
056B(0029) 42          |
056C(002A) 2D          |         byte  CLIT/2,$0D,EMIT/2,CLIT/2,$0A,EMIT/2
056D(002A) 0D          |
056E(002A) 49          |
056F(002A) 2D          |
0570(002B) 0A          |
0571(002B) 49          |
0572(002B) 48          |         byte  I/2,RCALL/2,36                        ' PRTWORD
0573(002B) 3B          |
0574(002C) 24          |
0575(002C) 3B          |         byte  RCALL/2,29,": ",0
0576(002C) 1D          |
0577(002C) 3A          |
0578(002D) 20          |
0579(002D) 00          |
057A(002D) 02          |         byte  _NOP,_NOP
057B(002D) 02          |
057C(002E) 2D          |         byte  CLIT/2,$10,BOUNDS/2,DO/2
057D(002E) 10          |
057E(002E) 0C          |
057F(002E) 42          |
0580(002F) 48          |         byte  I/2,CFETCH/2,RCALL/2,DM1-PRTBYTE
0581(002F) 23          |
0582(002F) 3B          |
0583(002F) 0F          |
0584(0030)             | DM1
  • AribaAriba Posts: 2,694
    edited 2012-07-03 22:49
    The reason that is must be long aligned is that the compiler calculates the difference of DM1-PRTBYTE in longs for the cog memory. You can not jump to a something in between longs in the cog. The result of the calculation is $0F according your listing. But I think you need the difference in bytes not longs.
    With a @ before the label you use the hubadress which is in bytes. So try this:
    byte  I/2,CFETCH/2,RCALL/2,@DM1-@PRTBYTE
    then the compiler will also not complain about not long aligned.
    Andy
    Ah, of course. As soon as you mentioned the @ operator the penny dropped. My head is such a mess, I should just stick to using the Propeller and then I wouldn't forget these things, I couldn't see it for looking. Thanks Andy!
    0560(002D) 48          |         byte  I/2,CFETCH/2,RCALL/2,@DM1-@PRTBYTE
    0561(002D) 23          |
    0562(002D) 3B          |
    0563(002D) 3A          |
    0564(002E)             | DM1
