WAM and Servo assistance needed
NWCCTV
On Pg. 130 of WAM 2.2 manual, utilizing the Homework Board I was able to create the circuit and all works well. What I would like to do however is to modify the program to use an If IN3 = 1, Pulsout and If IN4 = 1 Pulsout to go in reverse. My question is, which wire from the Servo would go to the pin I want to use for the Pulsout? I am thinking the red wire but I want to make sure before doing this.
Red is 5V and black is ground.
Lots of servos don't use white, red and black as the colors. The power line (5V) is always the center wire and ground is usually either black or brown. The other wire is the signal wire (often white or yellow).
Many servos will die very quickly if you reverse the 5V and ground lines.
