If I were to build a new robot, what type of casters should I use?
Casters?
Alternatives?
Pro's?
Con's?
Hit me with your best shot(s)...
-MattG
Alternatives?
Pro's?
Con's?
-MattG
I would have liked to use omni wheels but I could not locate any on short notice that had soft rollers. The plastic rollers are a bit noisy on hard floors.
Alternatives? Alternative Rock
Pro's? Parallax
Con's? Andy and Red
Hit me with your best shot(s)...Pat Benatar
Sorry in advance...
I would use single wheels on the castors. For the wheels I would use Colson Castors for both the main drive wheels and the castors. The thin variety for the castors. Use non-marring grey.
They are some of the best wheels you can get for a robot. I have some that have been in use for over 25 years and still work well. Not going to get that kind of lifespan from an inflatable....
Robert
why bother with something so primitive? It's time to upgrade!
-Tommy
No! With guys like the Gentleman in a Tailspin, Zoot, and Mr. Robot(shop) - there is hope...We shall continue to vanquish the Clowns of these Hallowed Forums to create a future and a hope for all that is Robotic...
Rolling right along-
-MattG
He works for the company that makes the ultimate caster...:thumb::thumb:
-Tommy
Why thank you TT...but I am serious :thumb:
We're thinking of a different platform/caster assembly concept right now, and I thought we should tap this "brain trust" (apologies to ProfBraino) for thoughts and suggestions.
I do wonder how well a nice, cherry or walnut caster would look.
Not
Well, Roll me up, and call me a hot-dog,
-MattG
I like what erco said about using a single tail wheel on rough terrain... There is also the steering tail wheel(s) option which is kinda fun and looks cool.
It depends too if you are going for zero turning radius or not. I would personally like to see Parrallax develope a multi-directional platform with 3 or 4 wheels.
What Whit and erco say make lots of sense. Parallax has the 3 wheel scene pretty well covered with a number of options from starters to big GUYS. A good 4 wheel platform would be nice, multi-directional wheels would be a great option and a balancer would be AWESOME. The processing power and peripheral sensors are all available. Providing a good experimenters platform in any of these configurations will be welcome.
Even a hexapod or some multi-legged walking configuration would be more interesting than another 3 wheeler.
...now, back to the peg leg and the emic-2 parrot.......
Besides, isn't two wheel balancing kinda obsolete anyway?
Eagerly awaiting the brain-power of this collective...
-MattG
Maybe it's time Parallax ruled the waters...
By Land, Sea, or Air, Parallax will allways be there... <<(i just made that up, You can use it if you want...:thumb:)
-Tommy
I also think that surface water robotics is an interesting field.
- Ken
The available Propulsion options for a water platform are staggering,
Anything from Propellers, to high power water pumps, and everything in between.
I have been leaning toward servo powered paddle wheels, as I have a small pond, and seems least likely to bother the fish..
-Tommy
The (true) omnidirectional casters used in heavy furniture is an option. These have *rubber* wheels and were made for fine furniture. These were available from Italy in the early- to mid-2000s, but the company that patented and made them apparently went out of business. I notice someone in the UK has picked them up again, or at least something that looks very much like the Italian casters of yore:
http://www.omnitrack.co.uk/OB-m.php
The OC50, 55 and 100 are probably the ones you might want to sample. The ones I used were the OC55 and OC100. The latter were popular among R2-D2 builders, and were very rugged. All of these were made for ball-down use, and turn a true holonomic 360 without points of friction when changing direction.
Note about price: In low quantity, wholesale the OC55 was about $15, and the OC100 was around $25 or so. Probably more now, but that gives you an idea of how these will impact your retail price. They aren't cheap, but they won't require custom machining like the Madeusa/Eddie casters now do (which, BTW, are excellent).
-- Gordon
You truly have to admire a writer that can work those words into one sentence!! :thumb:
Thanks you I'll be here all week.
Larger and not green! http://www.andymark.com/Mecanum-s/53.htm
