Simple Push Button Issue # 2
So, In this thread http://forums.parallax.com/showthread.php?140973-Simple-Push-Button-Issue Mike Green solved my first problem. The next thing I would like to do is add a second Push Button in order to spin the motor in reverse. I figured I better ask for advice on doing this before I burn anything up!!!
http://en.wikipedia.org/wiki/H_bridge
I just posted this attachment in another thread, but for you and only you I will post it again
The H-bridge is inherent in the DPDT configuration.
If you want a low-power solidstate solution, the BEAM H-Bridges are great for the DIYer.
http://www.solarbotics.net/library/circuits/driver_tilden.html
