Getting Serial output from MOBO 2PE
Question, I am trying to pull RGB values from a Taos color sensor connected to a MOBO 2PE via serial 232. I see that the prototyping board is probably the best route short of sticking wires into the daughterboard sockets. Are the SCL and SDA ports the serail command ports or am I missing something? Also, I have searched the manuals high and low and I do not see any where that it explains such a command to send the data. Any help would be appreciated.
I tried to find a example of someone using the serin/out codes, is there a link to any sample projects that actually works? every time I click on the sample projects link it takes me to a lost screen. I would really benefit from a working example.
