On/Off switch using digital clock
Hi All,
I have digital clock, using that I required to perform certain operation at particular time.
The basic idea is that, I required to convert on/off switch using clock existing functionality
As per below wiki link, I understand that we get binary data to digital clock.
http://en.wikipedia.org/wiki/Binary_clock
Can some one please suggest circuitry for making decision to put on and off condition.
Example :-
On Time :- 01:00:00 AM
OFF Time :- 06:30:00 AM
Be Happy
Example :-
Be Happy
Welcome to the forum. There are several ways to do this, the simplest from a hardware perspective would be to use a microcontroller to either input the clock digits, compare that to the on/off time, and turn an output pin on or off as desired. Of course with using a microcontroller the clock becomes redundant since it could also perform the clock function.
Just require information on programming side( Pseudo code) as well as IC information (AtgmegaXXX,PICXXX).
If you want to use an existing digital clock and interface it to a Stamp or Propeller, we would need some kind of schematic of the clock. There are too many variations on digital clock design to make general suggestions that would be useful.
If you want to make a clock, the Propeller would be the best. A QuickStart Board would work. You'd need some kind of a display. You could use the touch buttons of the QuickStart Board or ordinary pushbuttons for setting and controlling the clock and alarm. Here's an example of an object (library package) that provides a Real Time Clock function.
