BS2 vs BS2p strange behaviour
Started playing around with the stamps, and i have the following problem.
Basicly I have 12v + and - connected to the stamp, with a 5v reed relay connected to PIN 1.
The reed relay acts as a switch for a bigger 12v relay, grounding the 12v relay when I send the High command to pin 1.
Now this works perfect with the BS2 but with the BS2P, the instant I give the LOW command, the program just stops, sometimes restarting.
My first thought was that the relay causes a power surge, but since its when I send the LOW command, i am confused.
Any thoughts ?
Any thoughts ?
http://en.wikipedia.org/wiki/Flyback_diode
http://www.azatrax.com/relay-contacts.html
But I still find it strange that it behaves differently between the BS2 and BS2P....sure the same thing should happen on both if it was due to a spike.
An example of how to accomplish this can be found in the documentation of our Dual Relay Board Kit (#27114). I hope this helps.
