Analog to digital and scaling help with underwater ROV pressure sensor
Team,
I wold like to thank everyone here for thier help in the past towards my underwater ROV project. I have begun to work on the sensors. In paticular I have started work in the pressure sensor (manufaturing part number # P51-100-A-B-I36-4.5V-000-000). With help from the Analog to digital stamp in class book I have been able to get a 8bit adc reading 0.5~4.5V from the sensor and converting it to digital.
Now I would like to convert the code below to run with a Basic Stamp 2sx and 10bit ADC converter. Next I am looking to add more code to scale the readings to the 1024 resoulution the 10bit ADC puts out and read out in PSI and feet below sealevel.
Here are the knowns
- The sensor is a absoulute pressure sensor so 0psi = 0.5 volts
- The sensor is at about 1.00 volts at sealevel 14.5psi (1bar) (actual)
- The sensor is at 4.5 volts at 150 psi (10.34bar) (not tested but is promised off spec sheet)
- 100M (below sealevel) = 9.8 bar (142psi)
- 142psi = 328ft (below sealevel)
- 1ft = 0.4329psi
- 1psi = 2.31 ft
I am not great at math by any means nor am I good at programming (but i am learning). Using the above information how would one scale the sensor using BASIC to have it read the PSI and feet as i decend. Thanks.
[ Title ]
' Basic Analog and Digital - 150 psi absoulute pressure sensor
' {$STAMP BS2} ' will be changed to sx ver of course
' {$PBASIC 2.5}
[ Declarations ]
adcBits VAR Byte
v VAR Byte
r VAR Byte
v2 VAR Byte
v3 VAR Byte
[ Initialization ]
CS PIN 0
CLK PIN 1
DataOutput PIN 2
DEBUG CLS 'Start display.
[ Main Routine ]
DO
GOSUB ADC_Data
GOSUB Calc_Volts
GOSUB Display
LOOP
[ Subroutines ]
ADC_Data:
LOW CLK
LOW CS
PULSOUT CLK, 210 ' using a Basic Stamp 2sx do i need to chance the 210?
SHIFTIN DataOutput,CLK,MSBPOST,[adcBits\8] ' To convert to 10 bit do I change the
'8 to a 10 and that is it?
HIGH CS
RETURN
Calc_Volts:
v = 5 * adcBits / 255 ' by 1024 now?
r = 5 * adcBits // 255 ' by 1024 now?
v2 = 100 * R / 255 'by 1024 now?
RETURN
Display:
DEBUG HOME
DEBUG "8-bit binary value: ", BIN8 adcBits
DEBUG CR, CR, "Decimal value: ", DEC3 adcBits
DEBUG CR, CR, "DVM Reading: "
DEBUG DEC1 v, ".", DEC2 v2, " Volts"
RETURN
Thanks in advance
Here are the knowns
- 1ft = 0.4329psi
- 1psi = 2.31 ft
[ Title ]
' {$PBASIC 2.5}
[ Declarations ]
adcBits VAR Byte
v VAR Byte
r VAR Byte
v2 VAR Byte
v3 VAR Byte
[ Initialization ]
CS PIN 0
CLK PIN 1
DataOutput PIN 2
[ Main Routine ]
DO
GOSUB ADC_Data
GOSUB Calc_Volts
GOSUB Display
LOOP
[ Subroutines ]
ADC_Data:
LOW CLK
LOW CS
HIGH CS
RETURN
Calc_Volts:
RETURN
Display:
DEBUG HOME
RETURN
Thanks in advance
Your variables may have to go to Word values to accomodate the larger results returned from the a/d.
Anything to do with timing (PULSOUT, SERIN/SEROUT, FREQOUT) will change as noted in the Helpfile for the various commands.
Cheers,
Edit: I found it. I think this is what you are referring to. This may not be what you are looking for as far as the math goes, but it should get you started. This was actually for using a Piezo speaker. It is the CON value that makes the change for specific chips.
' {$STAMP BS2sx}
' {$PBASIC 2.5}
#SELECT $STAMP 'PULSOUT/PULSIN Scaling - conditional compilation
#CASE BS2, BS2E, BS2PE
PScale CON $0100
#CASE BS2P, BS2PX, BS2SX
PScale CON $0280
#ENDSELECT
#SELECT $STAMP 'FREQOUT Duration Scaling
#CASE BS2
FODScale CON $0100
FODScale CON $03C6
#ENDSELECT
#SELECT $STAMP 'FREQOUT Freq Scaling
#CASE BS2
FOFScale CON $0100
#CASE BS2P, BS2PX,BS2SX
FOFScale CON $0044
#ENDSELECT
We would have to know more about the 10 bit converter you are using. There is a lot of variation in how they work. You asked: The variable adcBits will certainly have to be a WORD instead of a byte in order to hold the 10 bits. The initial pulseout may or may not be needed--That is the sort of thing that depends on the exact converter you are using. I don't see anything in your program that would be affected by difference in timing between the BS2 and the BS2sx.
Scale factors to convert from adcBits to pressure or depth units too will depend on the reference and scale factor of the ADC. There are a couple of math tricks that can help with the math. For example, If your ADC covers a range of 500mV to 4500mV for a pressure range of 0 to 150psi, then the conversion multiplier is 1500/4000 = 0.375 in units of 0.1 psi. The Stamp can compute that by using the ** operator.
psi10 = mV ** 24576 ' where 24576 = 0.375 * (2^16)
