Graphics Driver Improvement and Optimization
Hey,
This is a follow-up from the thread
http://forums.parallax.com/showthread.php?140768-Prop-Code-Reduction-Tips.
So a while back, I happened upon someone's tile/sprite driver. I thought I could use it, so I tried it. It had what I needed, but there were some aspects that I went on to improve (TV picture quality etc.). In the end, I made a lot of mods.
What I wound up with was a graphics driver consisting of tile and sprite support:
The original driver was made such that the sprite routine ran after the tile routine. Since in the original build, the tile and sprite drivers both occupied the same space, the sprites were just run after the tiles. I can't do that now because I have separated the code across two cogs.
This driver may be over-ambitious, but anyone who has any suggestions, or even wants to try their hand at improving this is welcome. This link is the one for the driver that I didn't split up. I thought that I documented the best way I could, but if there is any confusion, ask me.
Graphics_driver.spin
gfx_renderer_sprite_4.spin
tv_drv.spin
Thanks in advance, guys.
- NTSC (can be adjusted for PAL)
- 256x224 resolution
- 8x8 tiles
- 16x16 sprites
tv_drv.spin
