Not a good start [sorted]
Before I start - I hope the following are taken as constructive comments! I'd like to learn C on the Propeller, so I'm offering my observations.
Any ideas how to overcome this? I could do Run As each time, but that's be a right pain!
Also, I noticed that the IDE doesn't maintain indentation (if I'm on an indented line and hit enter, the cursor goes to the start of a new line). I know C isn't intend specific, but I like well indented code - makes code following so much easier - is this a known issue?
Keep up the good work, I'm sure it'll be great soon
- So I tried installing SimpleIDE (WinXP), but it MUST be installed as an Administrator - not great, but I can live with that.
- I installed as an administrator (shift + right click, select "Run as...") and it seems toinstall OK - good!
- I run SimpleIDE and type in the "Hello world" demo, but then get errors when I try to run it (see below) - oops!
- I uninstall, then login as administrator and install again - GREAT, now I can run the demo
- I logout and back in as normal user - darn, still get errors (even after copying the SimpleIDE folder from the Administrator's "My Documents" to my own "My Documents" and ensuring that SimpleIDE is pointing to my version.
Project Directory: C:/!MyDATA/! ROBOTICS/Propeller/C/PropGCC_Work/blinky-001/propeller-elf-gcc.exe -o a.out -Os -mlmm -I . -m32bit-doubles -fno-exceptions blinky-001.c propeller-elf-gcc.exe error ... (0) propeller-elf-objdump -h a.out propeller-elf-objdump error ... (0) propeller-elf-objdump error ... (0) Done. Build Succeeded! propeller-load.exe -I C:/propgcc/propeller-load/ -b QUICKSTART -p COM6 a.out -rPropeller Version 1 on COM6 error: failed to open 'a.out' error: load failed
Please close the program then add c:\propgcc\bin to the "System variables" PATH - that should fix it.
Changing the PATH environment variables can be done by:
- Start -> right-click on My Computer
- On System Properties, click Advanced, then Environment Variables
- On click Environment Variables choose System variables Path, then click edit
- add ";C:\propgcc\bin" to the end of the Variable value.
- Click Ok to close all.
- Restart SimpleIDE
Thanks for reporting this. I'll add a fix to the installer.At this point we are responsible for our own indents. Sorry.
I'm a little annoyed by it being missing too, but other features were more important.
--Steve
