Simple? Xbee24 project
Use a PC with an Xbee as a transmitter to communicate with a remote Xbee.
On the remote side, the Xbee only needs to set DO high or low.
After trying various API commands and AT commands I was getting nowhere.
The Xbees passed the X-CTU range testing. But I could not set the DO line high or low remotely.
I eventually found an API command set that did accomplish my task.
cribbstechnologies.com
Using the X-CTU terminal in packet mode I could send
7E 00 10 17 05 00 13 A2 00 40 08 C9 80 00 02 02 44 30 05 20 to set DO high.
Then I would send:
7E 00 10 17 05 00 13 A2 00 40 08 C9 80 00 02 02 44 30 04 21 to set DO low.
I next wrote a visual basic code that continuously toggled the LED on the remotes DO line.
It was great; I walked around with the remote Xbee checking the range.
Then I wanted more range, I read about the Xbee net work being able to extend the range by using a different modes of operation. It seemed like I needed an Xbee in Router mode.
I played around with the firmware, and lost the functionality of my system.
I reset the firmware back to its defaults. Verified the Xbees are working (X-CTU range testing software). But now I cant get back to where I was with the PC side Xbee setting the remote Xbee DO line.
Help me please.
