Prop to Prop communication
Can I use the fullduplexserialplus to have two props communicate and pass data back and forth. I've tried, but don't get good results.
I've also tried the fast inter-propellor-communication file from the OBEX, but can;t get my props talking that way either.
Any suggestions ?
Any suggestions ?
I've found Tracy Allen's version of a four port serial driver works well for Prop to Prop communication since it includes a check for framing errors.
I've modified Tracy's version to check for an end of message character. When this character (I usually use a carriage return) is detected by the PASM driver, it increments a variable. When the main program sees this variable has increased, it then processes the message. This way I don't have to keep moving bytes around of partial messages.
I don't think I've posted my most recent modification. I'll post it if you're interested.
The downside to using an end of message character is you need to limit your communication to ASCII characters so your data doesn't include the end of message character. This is one of many issues that come up when deciding about a Prop to Prop communication protocol.
