ServoPal Help needed.
I would like to use a ServoPal to control a Pan/Tilt mechanism. The documantation and code that are online for the ServoPal only shows how to connect using the BoeBot Servo Ports. I would like to use Pin 0 and Pin 1. What I need help with is what resistor(s) I need to use between the ServoPal and the pins. Also, The code that comes with it is for constant rotation forward and backwards. After reading the instructions I am able to have 1 servo sto while the other rotates. The problem is that I want to use pushbuttons to control each servo and I am confused as to how I would code this since the ServoPal only uses 1 pin as input. I would appreciate any help you experts can advise.
