Small bug with console window
I just recently downloaded PropGCC and SimpleIDE for Mac. The install went really smoothly and the demos that I have tried all work as expected. I'd like to congratulate the developers on a fine job.
I have found one small possible bug in the console window. I've only noticed this when running a program that spits text to the console. If I click the "Disable" button as text is coming out on the console window, then re-run the program (using the blue/white arrow button at the top of the workspace), the program reloads into the prop and text starts coming out on the console, but the label "Enable/Disable" text doesn't reset to "Disable" is still says "Enable" even though the console is receiving and printing text.
Is this a simple label that wasn't toggled, or am I confused about how it should function?
Regardless a very small quibble with an otherwise excellent introduction to C on the Prop.
I'm not much of a C programmer, but this looks like a great way to start learning.
Thanks again to the development team.
Peter
Peter
I want things to work perfectly and you're helping that by mentioning the issue.
Thanks for your report.
--Steve
