Understanding Binary
G'day,
I've decided to not only make programs for the prop with the knowledge that I have, but to actually read up about programming them in general, perticually ASM. It got to the binary section in this (P16 - http://gadgetgangster.com/working_files/assembly_tutorial/potatohead.pdf) ASM tutorial and I thought that I ought to learn more about converting binary to decimal visa versa, so I took a look at this video (http://www.youtube.com/watch?v=tfKe8PPI2zs) which I found quite helpful. But then came the confliction. On P16 of the ASM tutorial on the first addition sum (binary) it said the answer should be 122, however, by my reconing, it should be 13:
Can anyone explain this?
John
11 11 <---- Carry
23 110
+ 99 + 111
122 1101 <----- Sum
128 | 64 | 32 | 16 | 8 | 4 | 2 | 1 |
1 1 0 1
8
4
+ 1
13
John
I will review that version. The decimal number example seems wrong. The important thing is the binary. Thanks for posting this.
If you run windows operating system, be sure and check out the scientific and or programmer calculator options. It can take and convert decimal, binary and hex.
Took me a second on that as well... till I realized the decimal and binary problems aren't the same. I suppose the 0030 fog might have had a hand in the confusion! ;-)
The decimal problem, in binary, would look like:
Amanda
