Getting PropGCC to build in fedora
Ok so I am working on a porting propgcc over to android and unvieling something very usefull to the forums!! Anyways I have been at it in my free time realitevly little problems just had to get a few libraries downloaded and add bstc.linux to my path. So ive got binutils built and proploader but I cant get propgcc built. The thing is Martin had this issue in this thread
http://forums.parallax.com/showthread.php?135710-Loader-Bug-Fixed&p=1050693&viewfull=1#post1050693
The thing is before I even looked on the board to solve this I installed Flex and Flex-Static libs..... I then saw the thing about adding those paths so I also tried that the ones in usr/local but I dont even have those directories soo im thinking maybe so much has changed Im suppose to have something else in my path?? I also went and re-did a make-install of binutils before posting to make sure there was no kind of dependency issues there.
/home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype.c:1264: undefined reference to `lexer_line' build/gengtype.o: In function `adjust_field_rtx_def': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype.c:978: undefined reference to `lexer_line' build/gengtype.o: In function `adjust_field_type': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype.c:1279: undefined reference to `lexer_line' build/gengtype.o: In function `adjust_field_tree_exp': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype.c:1205: undefined reference to `lexer_line' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype.c:1217: undefined reference to `lexer_line' build/gengtype.o:/home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype.c:1032: more undefined references to `lexer_line' follow build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o: In function `parse_error': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:138: undefined reference to `lexer_line' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:138: undefined reference to `lexer_line' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o:/home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: more undefined references to `yylex' follow build/gengtype-parse.o: In function `type': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:722: undefined reference to `lexer_line' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o: In function `type': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:793: undefined reference to `lexer_line' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:793: undefined reference to `lexer_line' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o: In function `type': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:754: undefined reference to `lexer_line' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:754: undefined reference to `lexer_line' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o:/home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: more undefined references to `yylex' follow build/gengtype-parse.o: In function `struct_field_seq': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:688: undefined reference to `lexer_line' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o: In function `type': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:778: undefined reference to `lexer_line' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o: In function `parse_file': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:947: undefined reference to `yybegin' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' build/gengtype-parse.o: In function `parse_file': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:982: undefined reference to `lexer_toplevel_done' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:987: undefined reference to `yyend' build/gengtype-parse.o: In function `extern_or_static': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:888: undefined reference to `lexer_line' build/gengtype-parse.o: In function `def_vec': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:914: undefined reference to `lexer_line' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:915: undefined reference to `lexer_line' build/gengtype-parse.o: In function `typedef_decl': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:838: undefined reference to `lexer_line' build/gengtype-parse.o: In function `def_vec_alloc': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:939: undefined reference to `lexer_line' build/gengtype-parse.o: In function `token': /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' /home/robert/build/gcc/gcc/../../../propgcc/gcc/gcc/gengtype-parse.c:49: undefined reference to `yylex' collect2: error: ld returned 1 exit status make[1]: *** [build/gengtype] Error 1 make[1]: Leaving directory `/home/robert/build/gcc/gcc' make: *** [all-gcc] Error 2
What Fedora are you running?
We have a build wiki page. http://code.google.com/p/propgcc/wiki/PropGccBuild
There is a prerequisites page too. http://code.google.com/p/propgcc/wiki/PropGccBuildPreRe
When Flex is run, it generates source code that has a yylex function, which is called by the parser to get tokens.
Your output indicates that the parser wasn't built. You said you installed flex, but did you do a clean before restarting the build?
